Crazy Overboosting
- Been thanked: 4071 times
On my T5 it was like getting a colonoscopy with a rusty wire brush. I vaguely remember having to turn one of the M6 bolts in 1/32 increments, clearance was really tight. The water pipe was in the way.
sventastic
- Year and Model: 1996 854R
- Been thanked: 6 times
This should give you an idea
1996 854R | M56H | 16T | 274k | BC, Canada
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 13 times
My understanding is the ECU limits boost in first and probably in second to protect the transmission from excessive torque, including manuals.WhatAmIDoing wrote: 18 Apr 2018, 21:49It is weird behavior, as I would have thought it would be the same in all gears. This is honestly really bizarre. Not really sure where to go from here.scot850 wrote: 18 Apr 2018, 17:22The standard TCv struggles to control past about 12psi. My 00 'R' has a tune, and it runs at 18-20 psi with the 19T turbo.It does seem strange that the 1st and 4th gears are ok and 2nd and 3rd are not. Cannot think why that would be as I would have had a problem with the wastegate or TCV would affect all gears as they all use pressure or vacuum.Neil.
M1 10W-30 HM
M1 10W-30 HM
- 45 Replies
- 8233 Views
Last post by MrAl
- 3429 Views
Last post by Sommerfeldt
- 907 Views
Last post by shiloh51933
- 1247 Views
Last post by FLXC90
- 11 Replies
- 1981 Views
