I use the f, c, and P words which have a lifetime warrantyFLXC90 wrote: 21 May 2018, 22:53Neil, can you post a link to where you get your swear words, mine are getting worn from overuse LOLscot850 wrote: 21 May 2018, 19:35 The damper/servo motor you need to get to is hidden on the RHS of the center section of the dash. To access it you need to remove the glove box liner and then you can drop the lower under dash. You will need a lot of patience and swear words as sell as a magnetic Torx driver to access the 3 small Torx screws that hold the motor in place. If you are trying to find one in the junkyard, then the one that controls the cold air damper which is behind the fan motor is the easiest to remove. It has only one Torx screw at the top front holding it in place, and you can slide the plastic arm off and is should come out easily.
'99 S70 - One side of dual climate control stuck on heat
- Has thanked: 1611 times
- Been thanked: 4074 times
