2004 S60 2.5T- Timing belt tensioner wiggles while running
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
The avatar one is not mine, but indeed it was a stunning color called Maya Gold, think it was offered only on 2001-2002. Internet pictures don't do it justice, in real life it totally looks like a special color
It was featured in a few promotional videos
www.youtube.com/watch?v=jdELBMTYt6A
www.youtube.com/watch?v=16bKxt_gwLU
For the belt 1mm side ways movement it's not bad, how much is the tensioner hand actually wobbling, in comparison?
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
If you ever need info on VVT replacement, then the thread below has everything you need.
Each new Volvo VVT is about $280.
Search the web, but the experience of rebuiling the VVT hub is not good. This is why people buy new VVT hub.
Large oil leak after replacing exhaust camshaft (cvvt) seal - help needed!
https://volvoforums.com/forum/volvo-xc9 ... ded-81251/
Kara503
Year and Model: 1996 850 Plat R-Swap
Has thanked: 17 times
Been thanked: 6 times
Post by Kara503 »
Tensioner hand is wobbling the almost the width of the window it is supposed to be inside. The center of the hand is going roughly from one side of the window to just shy of the other. Maybe 5mm total travel? Hard to estimate down there.I have a video but am not sure how to post it?
Cn90, thanks for the info :) What would constitute replacement of the VVT hub? If I find that it is the source of the leak does that mean it needs to be replaced? Also, where would I be seeing leakage from on the hub? As of now Im not sure if I can tell the difference between leakage of the hub, solenoid, or cam seal. Though I think at this point I will be replacing both the solenoid gasket and cam seal regardless.
96 855 Platinum- Elsa
98 V70R- Goose
06 S40 NA- Hilda
02 VW Jetta TDI wagon- Dizzy
jonesg
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
Kara503 wrote: 09 Jun 2018, 15:57 Tensioner hand is wobbling the almost the width of the window it is supposed to be inside. The center of the hand is going roughly from one side of the window to just shy of the other. Maybe 5mm total travel? Hard to estimate down there.I have a video but am not sure how to post it?
It could be the vvt solenoid is reacting slow, if the cam sensor at the other end of the shaft is loose.
That could send the vvt hub nuts and produce the movement youre detecting at the tensioner.
Just another thing to check.
Mine was loose and threw a code.
Kara503
Post by Kara503 »
jonesg wrote: 09 Jun 2018, 16:13
Would not have thought of that! Will make sure to check it once I have time to thoroughly investigate this. Thanks!!
That Maya Yellow is beautiful!! Will add to my dream fleet:
-96 850 Platinum Edition ( I own two!! :) )
-97 850 in burned orange metallic.... Not 100% certain on the actual name of the color
-00 V70R in Laser Blue
-02 s60 T5M in Maya Yellow
-07 v70 2.5t in white. Or get one repainted in the same color as the Platinum Editon :D
98 V70R- Goose
06 S40 NA- Hilda
mrbrian200
Has thanked: 7 times
Been thanked: 84 times
Post by mrbrian200 »
Whatever is causing the light misfire you mentioned is likely the culprit because varying inertia in the system will load the belt and make the tensioner wiggle with every miss. If you disconnect a fuel injector and observe the tensioner with a full tilt non-firing cylinder you should expect to observe the tensioner wiggle with every miss. I'm not ruling out the VVTs as others have suggested. But if that doesn't pan out with regard to solving your excessive wiggle problem, and I have my doubts, you'll need determine why the engine isn't running smoothly. Could be anything from a plugged injector to a bad spark plug or ignition coil, a sticky valve that momentarily torques the timing belt every time the cam lobe forces that valve open, up to and including low compression on a specific cylinder.
If for whatever reason you don't fix it, or determine the cost to fix more than you want to spend, then I would shorten the timing belt components and water pump service interval.
