I had a strange feeling it would come back...
If the O2 sensor code is still present, I'd definitely replace it. A bad O2 sensor could surely cause a problem with how the car runs.
Volvo 855T popping during deceleration
- Has thanked: 316 times
- Been thanked: 531 times
- henrysin44
- Year and Model: 1994 Volvo 855 Turbo
- Has thanked: 2 times
- Been thanked: 3 times
Me too, Volvos love to make you think you've fixed the problem, though it has to be either the MAF or the O2 or both. They're the only sensors I haven't replaced, plus I noticed I was boosting 2psi more than usual.bmdubya1198 wrote: 25 Jun 2018, 17:15 I had a strange feeling it would come back...
Daily driver Black 1994 Volvo 855 2.3L Turbo - manual swapped, turbo swapped, green injectors, custom M4.4 Tune, de-catted, custom two-tone interior, V70R seats & rims
Teal 1994 Volvo 855 2.5L N/A Manual Transmission (the back up daily and parts car) - Runs and Drives but the engine knocks
Silver 1997 Honda CRV 2.0 AWD - its in a very sorry condition, but drives
Silver 2003 Subaru Forester 2.5L N/A AWD - Leaks everything
Maybe the O2 sensor or MAF is what's been causing my car's stutter. It was running like crap today... stumbled on acceleration at least 4-5 times, rather than its usual stumble when I'm stopped.
- henrysin44
Ok so I swapped the MAF no difference, I pulled OBD I codes from under the hood to find I have 1-1-2 on A2 which is ECU failure, when I tuned my ECU I applied 12V to the wrong pins at one point and just assuming that probably killed it. Good thing I hid a M4.4 ECU at the scrapyard!bmdubya1198 wrote: 25 Jun 2018, 18:01 Maybe the O2 sensor or MAF is what's been causing my car's stutter. It was running like crap today... stumbled on acceleration at least 4-5 times, rather than its usual stumble when I'm stopped.
- Clemens
- Has thanked: 500 times
- Been thanked: 228 times
This all is the universe punishing you for running no cat...
Or maybe not.
Or maybe not.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
So I'm not the only one who does that!
- RickHaleParker
- Been thanked: 980 times
K&N gets the extra power by reducing the filtering capability. In other words it reduces the intake airflow resistance by allowing larger and more particles to pass. The particles are like sand in the engine, they increase wear and tear on the engine.
If you want to reduce the intake air flow resistance, use a filter with more surface area but the same filtering capability as OEM. You just need to figure out how to mod the setup to accept the bigger filter.
Active
Past
Past
Yeah, that’s why I’ve always been skeptical about those filters. I figured I would give it another chance and see how I like it on my R.
- RickHaleParker
You might like K&N until your rings and cylinder walls wear out prematurely ....
Active
Past
Past
After doing a little reading I might throw it on eBay. I went back to the Mann in my daily, might as well throw one in the R too.RickHaleParker wrote: 26 Jun 2018, 19:22 You might like K&N until your rings and cylinder walls wear out prematurely ....
My initial reasoning made sense... how more flow could you really get without letting in too much dirt?
K&N seems to be similar to Fram... they can sell like hot cakes, and they have no motivation to make a better product for that reason.
- 1262 Views
Last post by cn90
- 41 Replies
- 6730 Views
Last post by Seaway
- 68 Replies
- 11439 Views
Last post by 1ezliving4ume
- 1142 Views
Last post by vtl
- 11 Replies
- 2270 Views
Last post by wizechatmgr
