Another P2 question for you guys....
Has thanked: 1610 times
Been thanked: 4065 times
Mr. Detail wrote: 23 Jul 2018, 08:05 Thanks guys. Yes, that P/N 8642660 are the exact plugs I have ready to go.
What is considered "thin oil"? Like a can of 3 in 1 oil?
Concerning the cleaning of the throttle body, what is "Clean with hexanes"? Sorry I am new to some of these parts. I want to do it myself but need some wisdom from you guys.
Friggin chemists everywhere...
You clean a throttle body with 'throttle body cleaner'
CRC is the 'standard brand' you will find in your FLAPS (friendly local auto parts store)
The actual cleaner is a blend of hexanes, or 6 Carbon part of gasoline. Its volatile and bad for you, so do it in fresh air and wear gloves.
Mr. Detail
Year and Model: 2002 V70 N/A
Has thanked: 157 times
Been thanked: 6 times
Post by Mr. Detail »
LOL, abscate. CRC I understand and you have taught me a new acronym in 'FLAPS". Thanks for the warning.
Georgeandkira
Year and Model: '07 V70 + '15 XC70
Has thanked: 79 times
Been thanked: 71 times
Post by Georgeandkira »
By "thin oil" (and I do apologize for such vagueness) I was thinking of a few drops of 3 in 1 or penetrating oil.
I experienced some roughness upon removal of the plugs in my first V70. The 2 or 3 carefully landed drops of oil and a little working let the plugs turn out smoothly. Also, I was trying to differentiate between a few drops vs pouring ounces of oil down the well.
When you remove your first plug it may indeed be smooth going. If it howls and chatters as you turn your wrench, decide then.
If you want to start a small war, open a discussion of "clean spark plug threads" vs "anti-seized spark plug threads" then step back.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
abscate wrote: 23 Jul 2018, 09:23 The actual cleaner is a blend of hexanes, or 6 Carbon part of gasoline. Its volatile and bad for you, so do it in fresh air and wear gloves.
+1
Also try not to get it on your face/eyes, the spray jet may bounce off a surface. These carburetor cleaners have nasty ingredients that should not be inhaled at least not in a liquid form
I managed to clean the throttle body just with a clean and wet (water) piece of cloth without lint, it seems good enough, just clean everything on both sides
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
Main ingredient in CRC is Acetone 75- 85%, $6.00+ for 12 fl oz. Just skip the marketing BS and price gouging and use pure Acetone. When I need to clean something, I go to the cosmetics section of Walmart and get a bottle of ONYX Professional 100% pure acetone nail polish remover, $2.50 for 16 fl oz. Use a rag, brush or spray bottle to apply and pocket the savings.
Acetone is considered to be biological safe in normal use, it is the other stuff in the witch's brew that is the problem.
Active
Past
Did I mix up MAF and throttle body cleaner?
I’ll check labels in morning.
Acetone is also bad stuff with a link to cataracts. Fresh air for that too.
Both are extremely flammable as well.
oragex
Post by oragex »
I have used acetone to try cleaning an injector, but it damaged the injector. Not saying it's bad, but just my experience
On the other side, here's a chemical specification on a popular carburetor cleaner (it's a pdf file download link)
https://www.google.com/url?sa=t&rct=j&q ... HaCewzibbt
RickHaleParker
Did you soak the fuel injector in Acetone?
Full strength Acetone can damage the coil insulation and internal seals. The same can be said of full strength Seafoam and other harsh chemicals.
You got to watch what you use on plastics and rubber.
Active
Past
Mr. Detail
:D Thank you "RickHaleParker" for that Walmart/Acetone tip. Darn it I was just over at a Walmart yesterday. You out a smile on my face here early in the a.m. with the words "witches brew". :D
oragex
Post by oragex »
RickHaleParker wrote: 24 Jul 2018, 05:22 Did you soak the fuel injector in Acetone?
Yes, soaked it. Fortunately only one injector, the car was barely driving :oops:
