2005 V70 2.4 compressor removal..top or bottom
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
ohpoppy
Year and Model: 2005 V70 2.4&2.5
Re: 2005 V70 2.4 compressor removal..top or bottom
Post by ohpoppy »
it wasn't the compressor.. it was the compressor clutch needing to be respaced. here's what I did.
removed stuff on top and unbolted the compressor leaving the refrig lines on... propped it facing up and used a harmonic balancer puller to remove the clutch... just had to find 3 screws to fit the threaded holes. there was only one shim in it. it wasn't quite enough to leave me with .016 gap so i took very little off the seat at the compressor with a dremmel grinder. it measures now .014 and works well. its supposed to be .016 to .020" but I think if its cleanly spaced and spins free its fine.
time... 3 hours
funny how the top compressor bolts also hold down the alternator.. had to scratch my head wondering how the alternator came off.
ohpoppy
Post by ohpoppy »
time... 3 hours
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
Glad to hear you got it sorted out.
To wrap up your post - you could answer your question with some more detail so future members can benefit from your hands on experience. Would you take it out the top? What did you have to remove? What clued you in that the gap was off?
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
ohpoppy wrote: 30 Jul 2018, 14:03 funny how the top compressor bolts also hold down the alternator.. had to scratch my head wondering how the alternator came off.
Yes, that's a tricky one, glad it's sorted. As for the gap, in fact it could be as small as possible as long as it doesn't grab/touch the pulley when it's not spinning.
ohpoppy
Post by ohpoppy »
yes.. it came out top.. remove fan, ps pump unbolt and place out of the way (leave on hoses)..... alternator unbolt and place out of the way (leave on wires). unbolt compressor and reshim clutch.
