2006 Volvo XC90 won't go into park
woodg
Year and Model: 2006 S60 T5
Has thanked: 1 time
Post by woodg »
jimmy57 wrote: 31 Aug 2018, 15:06 after you did that it indicated R when you moved it as far as you could?
Yes.
2006 S60 T5
2001 S80 T6 Exec
2009 XC90 3.2
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
The cables used for gear linkage have a guide sleeve so that the cable can be pushed as well as pulled. If something was wrong with the cable it could block travel so that it can't go to Park position. Take the cable loose on trans end and try it.
woodg
Has thanked: 1 time
Post by woodg »
Thanks. I'll try that tomorrow.
2006 S60 T5
2001 S80 T6 Exec
2009 XC90 3.2
woodg
Has thanked: 1 time
Post by woodg »
jimmy57 wrote: 31 Aug 2018, 21:36 The cables used for gear linkage have a guide sleeve so that the cable can be pushed as well as pulled. If something was wrong with the cable it could block travel so that it can't go to Park position. Take the cable loose on trans end and try it.
We have a winner.....
Had some trouble getting the cable end off of the selector arm on the transmission, but once I did it went all the way home to park.
The force required to pop it off was enough that I was afraid of breaking it, but it did finally come off.
Ordering the new cable and recommended lock ring now.
Thanks for the help.
2006 S60 T5
2001 S80 T6 Exec
2009 XC90 3.2
