It attaches to the back. You can replace separately, making sure you disconnect battery First.
The cheaposcopes have 1 Megaohm typically so the battery wont hurt them
Persistent lights flicker
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 79 times
- Been thanked: 71 times
You sound new to this.
The VR is attached to the alternator's "back side". It's the black thing. They're around $60 (though I'm sure someone will be along to say they got their new one off Ebay for $3.50). It's replaceable. Read my post above.
Yes, it would be included with a new or quality rebuilt alternator. Good luck
Durenol
- Year and Model: Volvo 2007
- Has thanked: 2 times
- Been thanked: 4 times
No. The dealers and shops I talked to about using an oscilloscope to investigate this all said it was above their pay grade, and since I wasn't even sure what I was looking for I didn't bother trying myself. The best suggestions I got was just to replace the alternator and the entire wiring harness.
It hasn't seemed to cause any obvious problems, so I just ignored it.
- Has thanked: 2200 times
Do you have any aftermarket things plugged into the 12V socket, or an aftermarket radio? Just curious. Stuff like that can cause strange issues with the electrical circuits, alone with simple things like bad grounds.
Is it worth trying a set of LED headlight bulbs with a decoder to see if it can smooth the signal and remove flicker? I believe you can by decoders separately and might be worth trying.
Durenol
Nothing about this car is aftermarket except maybe the wiper blades. There are occasionally phone USB chargers or the like plugged into the cigarette socket, but not commonly. I don't think there were any back then when I last looked into this. Honestly I'm not sure it's even still flickering anyway, it was already subtle and I've probably subconsciously tuned it out. No one could ever see it until I pointed it out. Next time I drive it I'll try to remember to look.scot850 wrote: 14 May 2026, 10:11 Do you have any aftermarket things plugged into the 12V socket, or an aftermarket radio?
I don't even know what I'm doing when it comes to decoders. I don't ever spend any time under this car, and I don't really want to dump a bunch of money into random gizmos I'll only ever use once.scot850 wrote: 14 May 2026, 10:11 Is it worth trying a set of LED headlight bulbs with a decoder to see if it can smooth the signal and remove flicker?
Although your comment does bring to mind that I'm not 100% sure if I looked for the flicker in the interior with the headlights OFF. I guess I can try that too.
A decoder sounds fancier than it is. It does all the work. It basically plugs in between the headlight bulb and the headlight cable. It was I believed designed for LED headlight bulbs which 'flicker' as part of their operation. The decoder was designed as I understand it, to smooth the electrical signal and remove the flicker.
- 1217 Views
Last post by SleeStak69
- 982 Views
- 363 Views
Last post by 122sPhil
- 760 Views
Last post by j-dawg
- 4728 Views
Last post by gilbeynut
