Air Cleaner Assembly - Vacuum Leak Topic is solved
Jewl1215
Year and Model: 2005 XC90
Has thanked: 7 times
Post by Jewl1215 »
OK so it appears that the connector to the mass airflow sensor was previously glued closed because it may have snapped off at some point. Is it safe for me to clean the mass airflow sensor if I just go through the air filter box and not unplug it because there’s no way to unplug it
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
If it is in that bad of condition replace the MAF and the end of the wiring harness and be done with it.
Active
Past
Jewl1215
Post by Jewl1215 »
Well I cleaned it while plugged in. I think the part that’s glued to it is actually attached to the car’s electrical system. Is there a way I can post a picture of it on here?
Seems to still be symptomatic. Will def replace pcv. What, exactly, do I need to order if I want to tackle this myself? Can’t anyone help me with this info?
RickHaleParker
Jewl1215 wrote: 19 Oct 2018, 18:47 Is there a way I can post a picture of it on here?
Click :[Full Editor & Preview] below.
Click: [Attachments]
Click: [Add file], select your picture.
Click: [Place inline].
Click: [Preview] to see how it will look when posted.
Click: [Submit] when you are done.
Active
Past
shiloh51933
Year and Model: 04 XC70/'98 V70XC
Has thanked: 28 times
Been thanked: 17 times
Post by shiloh51933 »
I was going to suggest checking the plumbing at the turbo flanges, over time the constant heat kills the plumbing where the tubes mate to the turbo flange and even though it make look fine you actually have to remove that air duct to see behind the clamps. But your MAF sensor sounds problematic.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
Jewl1215
Post by Jewl1215 »
So it turns out, we needed to replace the turbo pipes going across the engine. They both had vacuum leaks. Also, replaced the PCV oil trap and some other vacuum lines, and cleaned the Throttle Control Module. Replaced the intercooler hose to the turbo pipe, too. Cleaned the MAF (then ended up replacing it & don't think it was even bad, so now a spare). Drives way better. However, still has a weird start sometimes. Maybe it's just normal? It mainly starts after the 2nd start, and this is mainly when it's been run for a while, not on 1st start up for the day. Would the start condition have ANYTHING to do with a "Service Alarm System Required" message that sometimes appears on start-up, then goes away? I'm going to double check the siren when I get home. Just also wondering if that has something to do with the start issue. Fuel pump was replaced in 2013.
