brake cleaner or carby cleaner?
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
Ive always used carby cleaner on the plastic turbo pipes, however looking at the data sheets using (without acetone) brake cleaner is much safer on plastics/rubber. theres an active ingredient in carby cleaner called TOLUENE that eats most plastics.
Actually i was thinking they were infact the same product under different labels, this is not what i found.
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
Has thanked: 1609 times
Been thanked: 4064 times
Acetone andTCE are in brake cleaner m for degreasing.
I think acetone andABS won’t be a good combination, considering I use it to smooth my ABS finished parts.
Toluene and ABS will be ok if you moisten cloth and wipe out the oil, but don’t immerse it ina swimming pool oftoluene.
Toluene is nasty shinola.....cancer!
Nitrile gloves and do it outside. Keep that spray out of your lungs
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Simple Green and let is soak, problem is it needs be rinsed - careful not to get water on top of the engine, the coils don't seal the spark plug holes
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
The older I get the more I worry about chemicals. Good thing. I had some bad habits before I got old and wise. LOL
I hope the young guys listen and don’t repeat our mistakes.
Get those cheap gloves and keep everything off your skin and out of your lungs
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
I agree with everything above. I use brake cleaner quite a lot as a quick degreaser, but I'm starting to question that. I often have it soak through good quality gloves. In years past, I had chapped peeling hands from carb cleaner.
They are both nasty to breathe, and in chilly weather in the garage, I'm not getting any ventilation. I went in to the kitchen for something, went back out into the garage, and the smell hit me like bricks.
BlackBart
Post by BlackBart »
Also - I just used some rust treatment paint for bare steel last night, and it gives you a headache right away. That can't be good.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
BlackBart wrote: 08 Jun 2020, 11:21 I agree with everything above. I use brake cleaner quite a lot as a quick degreaser, but I'm starting to question that. I often have it soak through good quality gloves. In years past, I had chapped peeling hands from carb cleaner.
correct, gloves can easily allow chemicals to pass, especially if your hands sweat due to the gloves themselves.
A world expert on toxicology spilled 2 drops of organic mercury on the back of her gloved hand,
she followed immediate protocol for cleanup .
Her hands had been in the gloves a while and the sweat formed an ionic bridge to pass the chemical. its scary out there.
It didn't end well for this "expert".
Nitrile gloves will let stuff through but dimethylmercury is nasty stuff, not stuff you run into routinely
If you think you will be cleaning a lot, double glove
Will nitrile gloves pass carb cleaner or brake cleaner? Acetone?
