Abs system
Ibro
Year and Model: 2003 s60
Post by Ibro »
hi..
to update .. changed the abs part. worked fine. but now again the same problem. maybe 2 months after installation.
could it be just bad luck that the part was not in good condition it broke again or should i check for another problem that might cause the unit to malfunction
thanks
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Many cars at junkyard end up there because of multiple problems. The last problem was the one that caused owner to give up on the car. At this age most used modules are faulty.
You can send your original module to BBA Remanufacturing and their fee is quite reasonable. They will refund the inspection fee if they can't repair.
