just purchased 05XC90 2.5, 230xxx Topic is solved
aaron1611
- Year and Model: 2006 XC90 V8
- Has thanked: 2 times
- Been thanked: 5 times
I won’t be back in town until later next week but will PM member. Not too worried about siren module. MAF has been cleaned and all vacuum lines nearby are good. No unmetered air getting in. No dip stick to check tranny fluid unless I’m missing something. I’m fairly confident it’s either pump or PEM. Will post back once in town.
2005 Volvo XC90 V8
2006 Volvo XC90 V8
91 240 Wagon 5 speed 211K daughters daily driver sold
2013 XC90 wife's daily driver 201K
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
Volvo's that were driven and flipped:
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
- SuperHerman
- Been thanked: 207 times
aaron1611
Nice. Will check fluid when I get back in town. Bizarre that my Bosch PEM part number does not show up online. Mine is 30636431. Can I purchase any PEM that fits my year and model despite it being a different part number?
2005 Volvo XC90 V8
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
aaron1611
so, just to follow up on this post now that I've installed the new PEM. I also installed two very strong magnets to the bottom of gas tank. We put almost 900 miles on the Volvo in the last 10 days with the new PEM installed and 3 times we felt the hesitation during acceleration over this period of highway driving at speeds around 70-75 mph but it threw the CEL after about 10 miles into our trip. I'm a bit confused now as to why this problem isn't consistent and what to do next. No other real noticeable problems driving the Volvo. I pulled codes today
212C long term fuel trim, bank 1 signal too high
21ED same as above
2900 fuel pressure-faulty signal-this code cleared once I replaced the fuel pressure sensor but it's back again
290D fuel pressure signal too low
430C fuel tank system-missing filler cap-will order new cap this week
434C fuel tank minor leak
439C fuel tank major leak
I'm wondering if the Purge Valve is faulty despite no code for it. Not prepared to replace fuel pump yet since the hesitation was an annoyance that resolved itself by letting off the accelerator. No stalling or anything either. Bizarre.
21ED same as above
2005 Volvo XC90 V8
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
- SuperHerman
Have you tried pulling the purge valve and then checking performance and codes? If it is working and then disconnected it should throw a code.
My experience if one keeps getting the same codes saying you have fuel pressure issues - then you have fuel pressure issues. You should do a fuel pressure test.
I am battling an overboost on my XC90 T6 and have narrowed it down to sticking waste gate flaps. Symptoms, other than actual codes, are similar to yours. Have you checked the action on your turbo actuator?
aaron1611
well, digging a bit deeper on the fuel pump duty cycle should be in the mid 30% at idle and mine are consistently in the low 50%. I'll rent the external gauge to check pressure at the rail but I guess replacing fuel pump is my next project since I'm still getting code 2900 with new FPS.
2005 Volvo XC90 V8
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
aaron1611
what about rebuilding the fuel injectors? I don't know the history of them but with 230K on the odom they are probably due.
2005 Volvo XC90 V8
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
- SuperHerman
What is actually rebuilt is limited. The actual injector is not touched. I would either source new ones or used ones with lower miles (and rebuild those if required). Honestly, if they look good I would save that project for later, once the vehicle is sorted.
Find shockwave's awesome thread about troubleshooting intermittent fuel delivery, pumps, PEMS, etc.
His root cause was a kinked fuel delivery line in the tank.
aaron1611
I did read shockwave's very long but great read. Ordered the pump but will check for kinks prior to doing the switch.
2005 Volvo XC90 V8
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
- 2177 Views
Last post by SuperHerman
- 17 Replies
- 3100 Views
Last post by MoVolvos
- 1856 Views
Last post by shiloh51933
- 2087 Views
- 39 Replies
- 5216 Views
Last post by York850
