2005 XC90 Where is the transmission dipstick on 2.5t
Otomaniv
Year and Model: xc90 2005
Post by Otomaniv »
:mrgreen:
Have a 2005 XC90 2.5t. Looking for yellow transmission dipstick. I found on drivers top of transmission
a black rubber hose with a black plastic top. Is that where the stick is supposed to be? Is it a breather? If so were should the dipstick be? Please help transmission in shuddering when accelerating at high speeds. Want to start with checking fluid before getting into it. Any info would be greatly appreciated :D
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
Move the lower radiator hose to the side, usually toward the driver's side, where it runs vertically in front of trans and you'll see it.
Otomaniv
Post by Otomaniv »
Thank you so much found the stick. Unfortunately it is not the problem of shuddering transmission. Any suggestions? Should i drain and refill? Do you know if it has a filter that should be changed? Just looking for guidance. Thanks again
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
I covered this topic in the DIY below.
DIY: 2005 Volvo XC90 2.5T: ATF, Angle Gear, AOC/RDiff Fluid
https://www.matthewsvolvosite.com/forums ... hp?t=64335
