Aircon compressor switching off and on in short intervals
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
precopster wrote: 26 Dec 2018, 15:04 I have icy lines to evaporator and a very high reading for evap temp such as 40degC so the above makes perfect sense. Have to look up access to that sensor on Vida if it's in there.
Does anyone know how to get to that sensor? Killing 2 birds here......
This is what I did on my P2. I put a sensor from a 2007up, those had black tip sensors (instead of blue tip ones)
Side note, when this sensor goes bad, the compressor spins like a squirrel not stop (reason for overcooling and frozen lines, blocked evaporator airflow, etc). Having the compressor run non stop like this for months (years) doesn't help the system. It may damage some valves, wear the compressor, block sections, etc. Once I replaced my sensor, it would work but not cool strong enough especially in the hottest days. Trying removing refrigerant, refilling, no improvement. I then went for the ghetto fix in the second video (total cost: $0.002 for a piece of tape) - however I use this only in summer, in winter I place the sensor back in place
