1999 Fuel Pressure Regulator Long Cranking (ECT replaced) Topic is solved
surfbug1
Year and Model: 1998 V70, 2006 S80
Has thanked: 41 times
Been thanked: 9 times
Re: 1999 Fuel Pressure Regulator
Post by surfbug1 »
GinPLUS wrote: 16 Jan 2019, 06:08 This ended up being the coolant temp sensor but at least I learned a few new things along the way.
hi
I'm having extended crank times
just curious, how does the coolant temp sensor come into play here, and why did this fix the issue?
al
Got a C3 Corvette corvette for sale? 1968 to 1981...not the 1982 crossfire injection
Ping me!
:D
wizechatmgr
Has thanked: 45 times
Been thanked: 126 times
Post by wizechatmgr »
surfbug1 wrote: 24 Sep 2023, 20:02
hi
al
Coolant temp sensor determines fuel mixture at start - if it's hot, less is needed, if it's cold, the mixture is enriched. When the sensor goes bad, it tends to guess towards the hot side, which means not enough fuel to fire correctly.
surfbug1
Post by surfbug1 »
wizechatmgr wrote: 27 Sep 2023, 17:33
hi
al
now it's starting fine, no delays
I will keep an eye on it, thanks for your reply!
Al
Ping me!
:D
wizechatmgr
surfbug1 wrote: 03 Oct 2023, 08:37
hi
al
Al
In my experience they first fritz at a particular temp and then full on fail. If that's the case, you'll find out when the season changes most likely, or smack dab in the middle of winter.
