2009 S80 "Engine Temperature High"
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
The vehicle needs a scan tool attached when engine has cooled completely, overnight is best, and then turn on ignition and get initial temp and see if it is plausible. If it is 8 C out and that temp from ECT sensor is not accurate then that is the first issue. Also check ambient temp from ECM to see that it is also accurate. Then crank engine and watch ECT to see that it rises somewhat steady and see where it goes. When it gets to 90C or thereabouts the upper hose should be warm or hot indicating circulation. Also an IR temp "gun" can be used to see what the rad temp is in line of sight areas across its width. The new thermostat may be faulty.
StevenStowik
- Year and Model: 2009 S80
I have a scan tool on order, it’s Volvo Vida... I will let you know the results once it comes in and I use it. Thank you all so much for the help so far!
- pgill
- Year and Model: 2010 S80, 2008 LR2
- Has thanked: 120 times
- Been thanked: 189 times
Steven,
Did you check the temperature as Jimmy suggested?
Looking at the Land Rover workshop manual for the same engine shows the following
This indicates that you are not get hot fast enough
See the post above from Rick (The temperature sensor for the outside air temp is behind the mirror glass as far as I know)
While you are waiting for the new scan tool verify the following
- Cold engine
- Turn on the engine let it idle
- turn off AC
- is the radiator fan running? It should be stopped
- how long does it take for the radiator fan to turn on
One last thing
Buy a coolant Hygrometer
Like this one
https://www.amazon.com/Thexton-THE106-A ... 0018&psc=1
How many balls do you have floating?
Read this link
https://hellafunctional.com/?p=629
If your radiator cap is defective then the engine could easily overheat a 50/50 mixture
Good Luck
Paul
- Cold engine
- turn off AC
One last thing
Like this one
Read this link
Good Luck
Paul
- 967 Views
Last post by LeovolvoS80
- 4724 Views
Last post by EChem
- 2906 Views
Last post by xHeart
- 991 Views
Last post by volvolugnut
- 573 Views
Last post by FLXC90
