If You are getting one atmosphere from a stock R tune you shortened up the wastgate
so that it inoperative.
R ECU drop in Topic is solved
- Has thanked: 2865 times
- Been thanked: 1332 times
My understanding of stock P80 R ECUs is that there was no increase in boost pressure. The only difference is the duration of allowed max boost... something like 30 seconds vs. 10 seconds.
I put a R ECU ("628" label) in my '97 T5 and didn't feel any difference.
Now if you have a 1994-1997 turbo (LPT or HPT) P80, put in a manual boost controller. That's some boost pressure difference.
628 Label R ECU info
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
Shortening the wastegate rod doesn't really change boost pressure, it moves the boost curve down the RPM range. That's why it bends rods. It might create boost spikes because the ECU doesn't expect it, but it will learn and "overcompensate", and you'll only see stock pressure, with earlier onset. And bent rods.tardcart wrote: 07 Apr 2019, 14:44 If You are getting one atmosphere from a stock R tune you shortened up the wastgate
The difference is between the T5 (222/225 HP) which were 9.7 PSI, and the T5R/R (240/250 HP) which were 12 PSI.matthew1 wrote: 07 Apr 2019, 15:24 My understanding of stock P80 R ECUs is that there was no increase in boost pressure. The only difference is the duration of allowed max boost... something like 30 seconds vs. 10 seconds.
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
Cool, thanks for the correction. I wish I would have measured the stock pressure to check this on my sample. I put in the R ecu, didn't feel any difference, and left it in, never going back and forth.Sommerfeldt wrote: 07 Apr 2019, 16:52
- S
tardcart
- Year and Model: 96 850t. 93 940t
- Has thanked: 3 times
- Been thanked: 37 times
The IPD tune costs 450 and a used 628r ECU costs 125 on Ebay. There is a reason people shell out the extra money for a ARD Green or IPD tune,(or used to) its much faster. even though its only 12 psi max. I want more but not until I get an exhaust and reverse intercooler pipes that I'm going to make, though it doesn't make money sense to make your own.
Sommerfeldt
The thing is that you don't need to spend 125 bucks on a 628 ECU. Get a cheap turbo M4.4 or M4.3 ECU, flash the BIN you want, and there you go. If you want an iPD or ARD tune, you'll have to shell out for it, of course...tardcart wrote: 07 Apr 2019, 17:24 The IPD tune costs 450 and a used 628r ECU costs 125 on Ebay. There is a reason people shell out the extra money for a ARD Green or IPD tune,(or used to) its much faster. even though its only 12 psi max. I want more but not until I get an exhaust and reverse intercooler pipes that I'm going to make, though it doesn't make money sense to make your own.
An iPD tune for my '96 will probably net me about 20-25 HP and half a PSI, so that's not worth it at all, for me at least. I'd have to ramp up in the stages... I do have a do88 RIP kit on mine, which I think makes the engine breathe better, though no special on the exhaust side.
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
tardcart
I would love to be able to flash an ECU. but I assume thousands of hours would be needed to get proficient. Im not good with non mechanical tuning. would love d088 rip and intercooler but poorboy it is all I can do.
- Has thanked: 1613 times
- Been thanked: 4075 times
Thousand of seconds needed for those who program stuff. Not difficult
I’m hoping we can inspire someone here to pick this up and make a few bucks on equipment and skills they already have. I haven’t programmed since the 80s although I did have do some Python last year in an emergency. Don’t miss that
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 129 times
If the bin files have already been mapped out and require no checksums, would be relatively easy to make modifications provided the microcontroller is known...
2023 Lexus RZ450e -66k
- 28 Replies
- 12195 Views
- 11 Replies
- 3159 Views
Last post by tryingbe
- 4550 Views
Last post by Clemens
- 2441 Views
Last post by shaker_chi
- 1595 Views
Last post by wyoben
