950c TPS error Topic is solved
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
Webpirate
Year and Model: 2006 s40
Re: 950c TPS error
Post by Webpirate »
Well what I've noticed is that my PedalE(the problem) no longer fluctuates. It sits at 7.8% reliably and steadily at resting position. I know this because I have an alarm setup in torque to go off if it drops below 7.8.
It used to fluctuate between 5.8% to 7.8%.
So if this is going to stay this way it was 1 of 2 things..
1) dirty connections on the cem
Or
2) tarnished fuse blades creating a connections.
I polished every fuse blade...
Webpirate
Post by Webpirate »
How do I mark this thread as solved. 8 days and no check engine light.
So it was either the tarnished fuse blades or dirty cem connections.
My PedalE on the torque app that used to fluctuate in the accelerator pedals resting position is absolutely stable at 7.8 when the accelerator is not being pressed(like when cruise control is on). What would happen before was it would be stable for a while and then start to fluctuate between 5.7 and 7.8 and then drop to 0 before the red triangle would come on.
After cleaning everything it doesn't fluctuate AT ALL unless you press the pedal.
I have circled the PedalE in the attached screenshot of the torque app.
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
Webpirate wrote: 12 May 2019, 18:53 How do I mark this thread as solved. 8 days and no check engine light.
Find the post that is the solution then, click on the green check mark.
