'95 850 Turbo - TPS Replacement Guide?
Relaximus
Year and Model: 850 Turbo, 1995
Post by Relaximus »
I've searched and come up empty. Is there a step-by-step guide for throttle body removal in order to replace the TPS?
Thanks!
Dave
'95 850 Turbo - 220k+
'05 S60 2.5T AWD - 88k
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
It is a pretty easy task. You will need to have a new throttle body gasket on hand but remove the throttle linkage from the throttle body. It is a ball and socket junction and you just pull it away from the ball to release it. From there unplug the TPS connector and remove the throttle body. The TPS is held on with two small screws. Remove the screws and replace the sensor. The sensor is keyed so it is hard to mess it up.
Clean up the old gasket from both the throttle body and the intake manifold and use your new gasket when re-installing it.
Year and Model: 2004 V70 2.5T
Been thanked: 466 times
Post by cn90 »
1+,
The following guide should help you:
http://volvospeed.com/volvo_repairs_how ... n_egr.html
Once done, make sure you adjust the throttle cable properly.
There should be a very slight slack on the cable.
Relaximus
Post by Relaximus »
Thanks guys, it's done! Cleaned the throttle body, MAF sensor, IAC motor and replaced the TPS. She's running great!
Cheers!
Dave
Has thanked: 292 times
Been thanked: 765 times
Post by erikv11 »
Maybe you want to take this opportunity to clean the throttle body up real well (often a needed service item), but keep in mind you can just remove the TPS with the throttle body on the car. The whole job will take maybe 20 minutes.
Remove those 2 bolts (like 7 mm head), remove TPS, replace.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
