would a bad maf or dirty maf cause it not to start, only sometimes?
Dan
Still Crank No Start. Very Strange
goldmandan
- Year and Model: 1999 S 70, 2000 V70
Possible but I would say rarely. You can disconnect it, then try (the car will run on a rmp/fuel map in software if there is no MAF signal)goldmandan wrote: 09 Jul 2019, 07:31 would a bad maf or dirty maf cause it not to start, only sometimes?
Dan
You will have to clear MAF code after that.
Dont unplug/plug MAF with ignition on, shut everything off.
goldmandan
i read ecm2400 is a short to ground in the wire from ecm to cem. Would make sense as the fuel pump relay was replaced already and i just put a new one in. no change. And the CEM does have a yellow wire going to starting/charging system. I think i may have found the culprit as the ecm2400 triggers right after i erase it and crank again.
