Favorite Brake pad?
Has thanked: 1611 times
Been thanked: 4075 times
Mr. Detail wrote: 13 Jul 2019, 12:09 One last brake pad change out question. I did look at a couple of online video's for our P2"s and specifically the rear pads.
Both video's the guy was removing the caliper. I thought that was not necessary for a simple pad replacement. is this true?
P80s have fixed calipers so the pads slide out.
P2s thecrear calipers float like the front, so off come the rear calipers for pad changes
Forgot to add my votes...Akebono x2
I had a brake job come up on my 1999 T5 recently, and based the experience with the inherited Akebonos on the S70, I went with those on the 1999. They do haul you down nice, fast, and smooth. I don't really care about brake dust. Elizabeth the T5 gets 95% highway driving at 65 mph.
Mr. Detail
Year and Model: 2002 V70 N/A
Has thanked: 158 times
Been thanked: 6 times
Post by Mr. Detail »
One last question on the replacement of my rear pads. Do I need to re-cut the rotors or buy new ones?
Trying to save a few bucks here.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
I think rotors need replaced when the wear is about 2mm deep/side (don't remember the exact number)
If yours are still good and not warped/scored, there is no need to replace them. However look inside at the parking shoes, see if there's delamination and look for rust on the rotor wear surface. These rear rotors may also be difficult to remove from the hub if there's a 'belt' of rust that causes the shoes from sliding off. Also good to look how the caliper spring sits, quite common to be installed back the wrong way
4 years in the Northeast. Perfectly serviceable..
As small boat anchors.
Mr. Detail
"As small boat anchors.", sweet!
