Favorite Brake pad?
Mr. Detail
Year and Model: 2002 V70 N/A
Has thanked: 157 times
Been thanked: 6 times
Post by Mr. Detail »
OK, I would value your guys opinion on what manufacturer of brake pads you like the best. Here is my list.
NO Made in China stuff.
Jurid, Pagid, Brembo, Bosch, Textar, Akebono & Meyle
Rattnalle
Year and Model: 2004 V70 2.5T
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
All the big brands have different series of pads. The Bosch stuff I put on my car lately was in part made in China, though I think it might have been the discs.
I'm curious to try ATE Ceramic pads since they're not too expensive and supposed to be relatively dust free. Current Bosch standard pads and Zimmermann standard pads before then are and were really dusty.
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
I like the Akebono ceramics. Reasonable stopping power and super low dust.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
Currently have a front EBC Set on a 2008 C30 T5 so can't really tell if it's just the pads alone or in combination. Nothing so far stops like it.
EBC S4KF1169 Stage-4 Signature Brake Kit
https://www.amazon.com/EBC-S4KF1169-Sta ... merReviews
MVS Contributor "pgill" has EBC brake pads only on all his vehicles with excellent results
viewtopic.php?t=89329
I also have 2 sets of Power Stop (Pad and Rotor) on an 03 Odyssey and O3 Lexus. They seemed great in the beginning but over the years they've begun to groan due to the slot and drilled combo.
For reference
https://www.amazon.com/K1077-Evolution- ... exus+GS300
The rear brakes for both cars are Nakamoto Combos (Pad & Rotor)
Brembo Rotors & Bosch Pads set is currently on the rear of the 2008 C30 T5. Fine & Smooth.
Pagid Pads on a 1995 E420 (was a great car till May 2010), Textar on friend's even older Benz from Autohaus Arizona.
They all work(ed) fine except for groaning of the Power Stops, nothing exceptionally better one over the other except the EBC.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Akebono ceramic.
93SCMax
Year and Model: 2001 V70 T5 mt
Has thanked: 36 times
Been thanked: 45 times
Post by 93SCMax »
E Showell wrote: 09 Jul 2019, 20:39 I like the Akebono ceramics. Reasonable stopping power and super low dust.
+1
Mr. Detail
Thank you guys!
Mr. Detail
One last brake pad change out question. I did look at a couple of online video's for our P2"s and specifically the rear pads.
Both video's the guy was removing the caliper. I thought that was not necessary for a simple pad replacement. is this true?
XC70Rider
Year and Model: 2007 XC70
Been thanked: 42 times
Post by XC70Rider »
Mr. Detail wrote: 13 Jul 2019, 12:09 One last brake pad change out question. I did look at a couple of online video's for our P2"s and specifically the rear pads.
The caliper needs removal to replace the pads. You can remove the bottom caliper bolt, just loosen the top bolt, then slide the caliper upwards to get the pads out of the bracket. The caliper piston needs to be pressed inward.
You got the pads and discs mixed up. To remove discs both the caliper and it's mounting bracket need removal.
Mr. Detail
Ok, thanks XCRider!
