Engine Oil recommendation ?
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
I've gone through four or five different brands of 5w40 in my car the last three years (70000 km with 10000 km intervals) and I've noticed absolutely no difference between them. Same almost non-existent oil consumption and sounds the same. All were low cost options at ~3€/litre so they could all have been from the same actual manufacturer, who knows.
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
Unless you drive like this you probably won't noticeRattnalle wrote: 19 Jul 2019, 03:37 I've gone through four or five different brands of 5w40 in my car the last three years (70000 km with 10000 km intervals) and I've noticed absolutely no difference between them. Same almost non-existent oil consumption and sounds the same. All were low cost options at ~3€/litre so they could all have been from the same actual manufacturer, who knows.
- Rattnalle
Yeah well.. I did try to find out the top speed in Germany (legally) but at 235 kph it started raining and I eased off. I do quite often floor it and use all the available revs to get to (reasonably) legal speeds though.MoVolvos wrote: 19 Jul 2019, 14:42Unless you drive like this you probably won't noticeRattnalle wrote: 19 Jul 2019, 03:37 I've gone through four or five different brands of 5w40 in my car the last three years (70000 km with 10000 km intervals) and I've noticed absolutely no difference between them. Same almost non-existent oil consumption and sounds the same. All were low cost options at ~3€/litre so they could all have been from the same actual manufacturer, who knows.![]()
- MoVolvos
OK, so it is you in the video.Rattnalle wrote: 19 Jul 2019, 15:57Yeah well.. I did try to find out the top speed in Germany (legally) but at 235 kph it started raining and I eased off. I do quite often floor it and use all the available revs to get to (reasonably) legal speeds though.MoVolvos wrote: 19 Jul 2019, 14:42Unless you drive like this you probably won't noticeRattnalle wrote: 19 Jul 2019, 03:37 I've gone through four or five different brands of 5w40 in my car the last three years (70000 km with 10000 km intervals) and I've noticed absolutely no difference between them. Same almost non-existent oil consumption and sounds the same. All were low cost options at ~3€/litre so they could all have been from the same actual manufacturer, who knows.![]()
Well then, not that I don't discount your experience but I've had the breathe of owning and maintaining a lot of car over the years and really tried a lot of brands. The latest was the Mobile 1 5-40W vs the Rotella 5-40W in a van that we've put over 70K miles. No question there is a difference.
One of these days I think I might compile a list just for fun before my memory... Oh, I was saying my memory.
- Has thanked: 1611 times
- Been thanked: 4071 times
June passed him 5 minutes in...MoVolvos wrote: 19 Jul 2019, 14:42Unless you drive like this you probably won't noticeRattnalle wrote: 19 Jul 2019, 03:37 I've gone through four or five different brands of 5w40 in my car the last three years (70000 km with 10000 km intervals) and I've noticed absolutely no difference between them. Same almost non-existent oil consumption and sounds the same. All were low cost options at ~3€/litre so they could all have been from the same actual manufacturer, who knows.![]()
- June
- Has thanked: 523 times
- Been thanked: 261 times
5 minutes?!!! I'm sure I could pass a Mercedes faster than that LOL. Unless I'm driving the C70 2.5T as it's surprisingly slow and the transmission likely would loose its cool!abscate wrote: 20 Jul 2019, 18:06June passed him 5 minutes in...MoVolvos wrote: 19 Jul 2019, 14:42Unless you drive like this you probably won't noticeRattnalle wrote: 19 Jul 2019, 03:37 I've gone through four or five different brands of 5w40 in my car the last three years (70000 km with 10000 km intervals) and I've noticed absolutely no difference between them. Same almost non-existent oil consumption and sounds the same. All were low cost options at ~3€/litre so they could all have been from the same actual manufacturer, who knows.![]()
Seriously 10W30 is the heaviest grade I would use. Since I switched to Redline 100% Synthetic oil I use 5W30 without issue year round. I still run the Hell out of my T6 even at 185K there is no end in sight for my engine. It runs flawlessly with tons of power and no oil consumption. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
- Rattnalle
YMMV as always with these things. Maybe I'm just not listening well. Or the ACEA ratings used here in Europe make the options more likely to perform the same.MoVolvos wrote: 19 Jul 2019, 16:37OK, so it is you in the video.Rattnalle wrote: 19 Jul 2019, 15:57Yeah well.. I did try to find out the top speed in Germany (legally) but at 235 kph it started raining and I eased off. I do quite often floor it and use all the available revs to get to (reasonably) legal speeds though.
- Rattnalle
Both grades you list have the same grade at running temperature. They're only different when cold. So 5w40 is actually heavier when running but the same when cold as your 5w30. The winter grade is only really relevant in actual winter when it's freezing.June wrote: 20 Jul 2019, 19:415 minutes?!!! I'm sure I could pass a Mercedes faster than that LOL. Unless I'm driving the C70 2.5T as it's surprisingly slow and the transmission likely would loose its cool!![]()
Harsh winters down there in Jacksonville. Sometimes , June puts a sweater in the car in case she gets delayed.
- Rattnalle
That's a sure indication you need to use the Russian engine heater.abscate wrote: 21 Jul 2019, 03:53 Harsh winters down there in Jacksonville. Sometimes , June puts a sweater in the car in case she gets delayed.
Lighting a bonfire under the oil pan.
- 2305 Views
Last post by chrism
- 707 Views
Last post by pvfjr
- 20 Replies
- 5451 Views
Last post by Krons
- 22 Replies
- 2601 Views
Last post by Shinotheweevil
- 12 Replies
- 1700 Views
