FrankenVolvo - What Modules Give a Volvo its Identity?
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
BobM wrote: 19 Aug 2019, 15:38 Maybe go back to my original idea to strip tires, rotors, driveshafts, and other stuff off both V70 and XC70 and get $300 scrap for the pair of them>
Bah! "I have an immaculate 2004 XC70 with a dead CEM" - so all you need is CEM reflash! In fact, 2004 was the last year when the flash and EEPROM chips were separate. Flash is "program", EEPROM is "identity". 2005+ has both functions buried in one encrypted chip.
I didn't try it myself, but it could be all you need is a donor CEM (same part number) and EEPROM chip transfer, which is relatively a basic work for any electronic hobbyist.
P2 (2001-2007) XC70 is the best car Volvo did in past 20 years.
vtl
Post by vtl »
Looking at 7 years ago when I paid bucks for the second hand XC70, I would get myself a 2004 XC70, not 2005. 2004 has most/all of the early years bugs fixed and the electronics is simple enough to allow me to keep the car up and running almost forever.
BeachWagon
Year and Model: 2002 V70
Has thanked: 7 times
Been thanked: 2 times
Post by BeachWagon »
Forgive me for the dirty talk but....
Have you considered contacting a Volvo dealer or independent shop who happens to have a legit version of Vida? Can't they program your salvaged CEM into the other car?
vtl
Post by vtl »
They do not load sw into a used CEM.
BobM
Year and Model: 2004
Post by BobM »
vtl wrote: 19 Aug 2019, 15:23 All XC70 P2 ever had in US is turbo engines, 2.4T or 2.5T. 2004 is 2.5T. Not gonna work with V70 ECM unless it was using same engine as well.
Hmmmmmmmm.....
This makes me ask 'Why Not'?
If I drop the 2.5 motor and transmission into the V70 body, how would the electronics know that there is 200cc of additional capacity?
- All the engine and transmission sensors are the same
-The ECM controls the fuel injection which is governed by the front oxygen sensor - not related to the engine directly
- There would be no turbo.. use V70 Exhaust Manifold
- the ignition advance curves may be slightly different.... I promise not to go racing in the V70
- The unused exhaust CVVT would run in its static position...I promise not to go on any fuel economy runs with the V70
- Exhaust camshaft position sensor would be not connected.
Thoughts.......????
BobM
vtl
Post by vtl »
How would Denso natural aspiration ECU know that the new engine has a different compression ratio? I don't know, you try and tell us :-D
Has thanked: 1609 times
Been thanked: 4065 times
Ill give it a shot
Turbo and NA pressure sensors are different >>>> ECM code
FI controlled by ECM via inputs from load, OXS, MAF, temp, pressure , ECT - at least two of these are different >>> ECM code
ECM code for missing MAP and "pressure reading unlikely" or some code like that
Drastically since they are boost dependent
?>> Code for missing solenoid signal and low 12VDC
On the plus side, if you put in red and green LEDS on the CEL, it would make a nice Christmas tree.
BobM
Post by BobM »
abscate wrote: 22 Aug 2019, 08:54 Ill give it a shot
I agree if I was putting the V70 into the XC70, there would be a number of missing sensors, inputs and controls.
My proposal is to put the XC70 motor into the V70 and run it without turbo, no exhaust CVVT,, the V70 ECM wouldnt be looking for solenoid state.its not wired. Ignition timing would be for no boost V70 (no turbo). likewise V70 isnt looking for MAP input
