New question: Is it possible the ABS unit might be causing this?
On other fronts, my brother is familiar with windoze and has an old laptop I can have. I sent him a link and he downloaded VOL FCR to it for me. I ordered this for him to use as a cable; https://www.amazon.com/findway-Version- ... op?ie=UTF8. He has an 850 wagon he can test it on so I'll let him hopefully get it hooked up and figured out before I see him.
I also ordered this for me today;
https://www.amazon.com/iCarsoft-i906-Co ... B00S8KJHBM
I'm hoping it will be better than my current scanner which I will give to my oldest so he can reduce his reliance on me when either of his 2 850s act up. At least he can pull engine codes and look at live data with it.
will 0137 code send trans to limp mode?
- greg850r
- Year and Model: a long list
- Has thanked: 5 times
- Been thanked: 26 times
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
99 C70 Convertible
96 850R wagon
96 850T wagon
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
- greg850r
The scanner arrived and it does read transmission and ABS codes as advertised because I tried it on my driver 850 GLT. When I plug it in to the wagon with no 4ht gear however it says there are no codes in the TCM. It also says fail to connect to ECU. I was hoping not to examine every pin in the OBDII socket and the computer sockets but it's looking like I need to find the time to get a pinout and do that.
Update: the cheap Harbor freight scanner that won't read transmission codes DOES find the engine control module and read it. The icarsoft unit still says no ECU connection but does connnect to the transmission control just fine. Oh, and I unplugged the ABS unit because I've read that could be a problem (and this car has a bad one) but there was no change.
99 C70 Convertible
96 850R wagon
96 850T wagon
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
99 C70 Convertible
96 850R wagon
96 850T wagon
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
