Rear bumper bracket, Rear Sway bar information
rguzz
Year and Model: 1996 850 turbo
Been thanked: 25 times
Post by rguzz »
If it's in the shop for the sway bar let them do it. IIRC one of those bolts sits right on top of the rear exhaust pipe, and takes a beating from all that heat. Odds are you will break one of the two off, which I of course did. I replaced with two new ones, genuine Volvo, 11-12 bucks a piece, maybe? Car lived in SE USA all it's life as well. Rest of the job is easy, though, fender rivets minor PIA. New brackets, yeah for sure.
850forum
Year and Model: 1995 850 turbo wagon
Been thanked: 6 times
Post by 850forum »
Well... the mechanic, who owns a Volvo, says there is a weld involved, so its a bodyshop job to take it apart.
Anyone think this is correct for a 1995 850 turbo wagon?
Maybe I'll take that offer of a pair of brackets, and get the rest of the hardware, and try doing it myself if it doesn't keep raining.
But they are getting a junkyard sway bar since they don't make them anymore... seems they have several odd diameters, down to a fraction of a mm... Other pieces & bushing were no problem.
NEVER OPEN THE HOOD !!!
850forum
Post by 850forum »
IDPA is giving slightly different volvo PNs than in this post:
1999 V70T5M56 Rear Bumper Bracket Replacement 6816114 and shock cup 3546435
abscate » June 26th, 2018, 11:21 am
2 each 6816114 Brackets
IDPA says volvo says 6816115
4 each 988182 986504 Flange Screw
IDPA says volvo says M10x20 988182 the short ones
2 each 982831 Bracket screw (the long ones; called flange screw by volvo)
IDPA says volvo says PN 982833 for the long ones
ALSO 6 POP RIVETS FOR THE FENDER ATTACHMENT - any blind rivet.
He says that the flange screws are a hardware store item as long as I can find the good quality ones not the cheap junk usually sold. What am I looking for, is "class A" the term? I know good bolts have one, two, or three lines on the bolt head showing their strength.
Has thanked: 1613 times
Been thanked: 4075 times
Standby
rguzz
Post by rguzz »
Has thanked: 312 times
Been thanked: 818 times
Post by erikv11 »
850forum wrote: 24 Oct 2019, 11:21 Well... the mechanic, who owns a Volvo, says there is a weld involved, so its a bodyshop job to take it apart.
Anyone think this is correct for a 1995 850 turbo wagon? ...
No.
My 95 was a sedan, but no welds when I did this repair there. And no welds when I did it on my 96 wagon. And I've never heard of anyone dealing with welds for this repair, back to 93 model cars ...
from viewtopic.php?t=56982&p=288019 the best way to tell what diameter a P80 sway bar is, is by the color of the paint splotches on it:
front sway bar part #s:
9173982 O.Dia 20 mm (marked red)
9173983 O.Dia 21 mm (marked yellow)
9173471 O.Dia 21.5 mm (marked yellow/blue)
rear sway bar part #s, probable O.Diameter:
9191459 (marked green) 19.5 mm
9191461 (marked yellow) 20 mm
9191462 (marked blue) 20.8 mm
9191494 (marked black) 21 mm
It's nice to get a thicker bar if you can, but the green one in the back is better than none at all back there.
9173982 O.Dia 20 mm (marked red) [font=]available as of March 2020, about $180[/font]
9173983 O.Dia 21 mm (marked yellow) available as of March 2020, about $180
9173471 O.Dia 21.5 mm (marked yellow/blue) [font=]NLA - shows backordered with no date.[/font]
9191459 (marked green) 19.5 mm available as of March 2020, about $150
9191461 (marked yellow) 20 mm NLA as of March 2020 NIVOMAT
9191462 (marked blue) 20.8 mm available as of March 2020, about $150
9191494 (marked black) 21 mm available as of March 2020, about $150
kklepack
Year and Model: 2016 XC60
Has thanked: 12 times
Been thanked: 5 times
Post by kklepack »
kranz wrote: 22 Oct 2019, 16:56 I have a rust free pair complete with hardware. We don't know what rust is here. Yours for cost of postage. That is unless you already made a deal with Abscate.
OOps, I may have spoken too soon. These came off of a V70. Check for compatibility with an 850.
Part number is 6816114
Do you still have them? If yes, what it would cost me with shipping it to 60634.
kranz
Year and Model: '98 V70 NA stick
Been thanked: 8 times
Post by kranz »
I just have one bracket and one bolt at the moment.
Les is more.
I think I have two decent ones of Clarke, and I have two new bolts, but shipping will kill it.
You can buy brand new with free shipping from FCP for about $50 all in, add brake bleeders if you are a bit short of the thresh hold
