1999 V70T5M56 Elizabeth Voltage Bus problem [Old battery on last legs] Topic is solved
Has thanked: 1610 times
Been thanked: 4065 times
Okay, just for those still playing at home.
I left the taillights on for 15 minutes wiring trailers, and the whole car was dead.
So this battery is down to about 2 Amp hours reserve capacity, yet still starts the car.
Has thanked: 2200 times
Been thanked: 1852 times
When I changed the 'R's battery last year it was already cold. Temp was around -20C. I had not being using the car much and knew the battery was passed it's best, although disappointed as it was less than 5 years old. It was regularly on a trickle charger but had a week cell for a long time. This was ok when in warmer temperatures >10C, car would start and run fine. But as soon as it got cold, the car would run rough and lumpy. Only cure was a new one. Interstate high crank battery and about $180 CDN.
Now just have to use the car more to keep it exercised. The 'boss' has offered to use it regularly as it fits her golf clubs better in the back than her Kia Sportage does!
Meant to add, hopefully it is just the battery on it's last legs.............! :D
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Unlike most things, when batteries get weak they go faster.
Roger_850T
Year and Model: 854T 1995
Been thanked: 26 times
Post by Roger_850T »
What voltage do you see on it when the car is running? At the battery terminals, as well as at the alternator output lug? I have had high resistance in the battery cables cause it to not charge as well as it might, with similar symptoms to what you describe. Fixing the cables, I ran the battery for another year or two because I fixed the root problem.
11 XC60 137k
08 V50 Project... Still in pieces
05 XC90 V8 213k
95 854T 350k Still my favorite daily driver
02 V70 186k+ Gave to my daughter, still going strong
03 S80 111k (crashed, but driver walked away unhurt)
93 945T 217k (gone to be parted out)
87 245 300k+ sold, still going afaik
84 264 Diesel, RIP at 160k
78 242 manual everything.
73 P1800ES, fun until the rust set in...
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
abscate wrote: 05 Jul 2020, 15:57 Okay, just for those still playing at home.
Interesting! I am experiencing the same thing with my VW T4. Repeated starts don't matter (which usually should drain a battery good on a diesel) but leave the parking lights running for 2 hours and I have to use it's second battery to jump start it.
1996 855 R,
2010 V70 D5,
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
I wonder how much longer that alternator is going to live... Might go nuclear like mine did...
Alternator is pretty new. I’ll top it off on charger but if I can’t keep it above 25% charge it has to go. My 90 year old mother drives the T5 on occasion , of course, if it won’t start she would probably get out and push it. She used to get home from night school in Buffalo by starting her 6 V VW with her purse strap used like a lawn mower starter. That was back before she was self-sufficient.
wizechatmgr
abscate wrote: 12 Jul 2020, 10:33 Alternator is pretty new. I’ll top it off on charger but if I can’t keep it above 25% charge it has to go. My 90 year old mother drives the T5 on occasion , of course, if it won’t start she would probably get out and push it. She used to get home from night school in Buffalo by starting her 6 V VW with her purse strap used like a lawn mower starter. That was back before she was self-sufficient.
An incredible woman on any day =)
Hard crash on the old battery. Car sat for one day and no crank.
Replaced with my spare boat battery from 2015 for now
Got 7 years out of this one!
