UPDATE!
It’s been doing the flickering a bit more often, but still only at idle, looked over a few other things, the battery to starter wire isn’t as bad as I thought once I removed a bit of the heat shrink.
Wondering if the PO had routed the serp belt the old way (less contact on alt pulley), I had a closer look. It’s routed the updated way, but when I checked tension, I realized it didn’t really have any, except I guess under load. I could move the tensioner pulley fore and aft a bit more than is probably acceptable.
So, I’ll be putting a new tensioner and belt (might as well, right?) as soon as time and shipping allows, assuming there aren’t two perfect examples at the pullapart tomorrow.
Will it solve the flickering? I hope so, but it seems like the car needs it anyway.
97 850 dash/headlights flickering only at startup. UPDATED
- misha
- Has thanked: 155 times
- Been thanked: 432 times
It could be that voltage regulator brushes are worn out.
Diodes should be checked too and alternator tested by a specialized shop.
About serpentine belt tensioner....you shouldn't be able to move it by hand.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Peevarino
- Year and Model: 2009 XC70, 97 855R
- Has thanked: 28 times
- Been thanked: 3 times
I’ll be pulling a couple voltage regulators out tomorrow, as well, I seem to recall a couple newer looking alternators in the few P80 cars at the yard.
09 XC70 3.2
97 855R
97 855R
- misha
The easiest thing is to try with replacement tensioner.
If that doesn't cure it....than attack the alternator.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Peevarino
That’s the plan, tensioner needs replacing anyway. If the alternators’ brushes look good at the junkyard, I’m going to get them, cheap backups just in case.
I really wish I had gone to the junkyard yesterday, though, it’s almost 30 degrees colder today.
09 XC70 3.2
97 855R
97 855R
Peevarino
Found a properly working tensioner and pulley at the junkyard, along with a nearly new Volvo stickered Bosch alternator. The PO put in a O’Reilly reman alt at some point, so I figured get it when I can.
No time left to put tensioner in today, family time and grocery run take priority now.
I’ll report back once the tensioner is in, I may have time on my lunch break tomorrow, assuming it’s not raining.
09 XC70 3.2
97 855R
97 855R
Peevarino
Tried disconnecting starter to battery cable and replacing with a new, no change.
Replaced the two block to firewall ground straps, and the flickering seems to have stopped. Sadly not commuting to work at the moment, so I can’t give it a proper test drive. Maybe I’ll take it for a spin tonight or early tomorrow morning and get a better test.
09 XC70 3.2
97 855R
97 855R
- 2681 Views
Last post by SuperHerman
- 22 Replies
- 1127 Views
Last post by dikidera
- 3429 Views
Last post by ShadowDancer
- 4554 Views
Last post by chocolate chimney
- 2560 Views
