Ob2 port won't read codes, personal reader and store reader - 99 s70 na Topic is solved
smacknab
Has thanked: 97 times
Been thanked: 43 times
Post by smacknab »
abscate wrote: 29 Dec 2019, 20:59 Check the voltage from 16 to a chassis ground to see if pin 16 has battery voltage
Pin 16 to the frame near the driver's side door hinge read about 2 mV
I'll check the under dash fuses when it stops hailing, but thanks to everyone for chiming in. To be honest it's a little over my head at the moment but I'll check the fuses soon and report back what I find
07 V50 T5 AWD M66 ~146k miles
Has thanked: 1609 times
Been thanked: 4063 times
If I plug an OBD READERinto a 1999 am I reading on the K line or CAN BUS?
Will it depend on the protocol of the scanner, perhaps?
smacknab
Post by smacknab »
Someone suggested I check that it's plugged in, looks good to me.
Still waiting for dry weather to check the lower fuses
jimmy57
Been thanked: 322 times
Post by jimmy57 »
K line is what Generic readers use. K line is used by VIDA (and some others I suppose) to tell the CDM (inst cluster) to open the gateway and connect high speed CAN wires.
If the scan tool came on, display was on, but wouldn't communicate then K line issue is likely. If the tool did not come on then the pin 16 wire or ground is suspect.
smacknab
Post by smacknab »
jimmy57 wrote: 30 Dec 2019, 11:17 K line is what Generic readers use. K line is used by VIDA (and some others I suppose) to tell the CDM (inst cluster) to open the gateway and connect high speed CAN wires.
No display came on. I'm going to get some contact spray and try that. When you say ground, does that mean any ground in the car? I did just take the head off and reassemble the car, so possibly i missed a ground wire in the engine bay on reassembly?
You’ve got no voltage on pin 16 on the OBD
Start tracing backwards from that pin to see where you lose the 12 volts
That’s the systematic approach
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
11A/6 & 11C/5 fuses under hood.
24/2A Connector Green 12-pin (male- female)
Engine compartment cable harness - Firewall cable harness
24/7B Connector Natural10-pin (male- female)
Firewall cable harness- Tunnel cable harness
Active
Past
smacknab
Post by smacknab »
Found it! Fuse 11c/5 was blown. Ob2 is scanning again. Thanks everyone for the hand holding, I didn't know that the fuses had different designations based on their location!
Excellent. There is one weakness with the incredibly well-done Volvo wiring diagrams
Sometimes, you want to know everything that is on a circuit so you can figure out what is making the fuse blow.
1 You can famously RTFM and read the fuse systems in the manual (Volvo manuals are all online for free)
2 You can look at the back of the fuse and color/mechanically trace the wire
3 You can hunt through all the wiring diagrams and look for references to the (example above 11C/5) fuse designation.
SM - for the 11C/5 I think this circuit feeds:
Engine cooling fan
ECC climate control
MCC climate control
Diagnostics
so if it blows again, that's the list of things to check
RickHaleParker
11C/5
  • Engine cooling fan (FC)
    Diagnostics (OBD pin #16)
    Standard heater
    Manual climate control (MCC)
    Electronic climate control (ECC)
Active
Past
