Fly wheel bolts
Has thanked: 1610 times
Been thanked: 4065 times
Flex bolts with Loctite maybe re-usable - pretty low torque
Flywheel bolts to crank? Hmmmm
dobrosailor
Year and Model: 2002 Vovlo C70
Has thanked: 5 times
Post by dobrosailor »
Ok replaced the bolts with new ones and they torqued down fairly easily. Thanks all!!!
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
dobrosailor wrote: 03 Mar 2020, 03:34 Ok replaced the bolts with new ones and they torqued down fairly easily. Thanks all!!!
The old bolts where already stretched like they should be. The new bolts had never been stretched. That is the difference. The + 65° is the stretch.
On the old bolts you where trying to take the stretch to like 130°. When you do that you run the risk of yielding the bolt. If you don't do the stretch you run the risk of the bolts coming loose.
Can one get away with using old bolts. Yes and many do but, it is a crapshot. When it works you save a few bucks, when you lose it is a big lost. You got to do all that work over again.
The quickest way to get a job done is do it right the first time because no job is done until it is done right.
Active
Past
