Steering Wheel Stuck Locked - Key Not Turning 2003 Volvo S60
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
abscate wrote: 28 Jun 2022, 23:59 It’s tough drill because you can’t get a drill straight down due to the lip of the dashboard cowl around the instruments.
When the column lock is not going to be reused. Cut it off from the sides with a Dremel cutting wheel.
Active
Past
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
I got a milwaukee drill adapter, small profile for tight spots .
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
If the problem is due to a jammed tumbler then cutting up the column lock assembly isn’t going to fix it. There is a way to surgically extract the tumbler and fix the internals so that it won’t jam any more. I’ve done it on my own 2003 V70. If interested I’ll try to find the YouTube video that describes the process.
