Chicken!
Sanity Check: Evap Purge Valve Stuck Open?
- RickHaleParker
- Been thanked: 977 times
Active
Past
Past
Richard99
- Year and Model: 2000 V70XC
- Has thanked: 26 times
- Been thanked: 23 times
This...RickHaleParker wrote: 27 Feb 2020, 17:28 A stuck Canister purge valve would produce both of the DTCs.
During the test of the EVAP Canister shut-off valve, the Canister purge valve is pulsed. If the canister purge valve is stuck open the pressure drops too fast and the test fails.
The Canister purge valve is normally closed and opens when 12V is applied. Disconnect the wiring harness and hoses to the Canister purge valve and blow, it should be closed. If it is closed, look for a hose leak between the Canister purge valve and the Canister.
Eric
1998 Volvo V70 - rear-ended and totaled
2000 Volvo V70XC
2007 Volvo V50 T5 AWD M66
2000 Volvo V70XC
jimmy57
- Been thanked: 322 times
The shutoff valve is there to allow tank leak detection testing. On that 98 it would only close after you drive for a qualifying period with some driving conditions met. Once you idle it can do the test and close the shutoff valve, the only reason it ever needs to close the vent line for tank. The purge valve runs a lot. If you idle for 30 seconds or so then it will do a test to see if canister has load by opening purge valve and watching response at front oxygen sensor. If it goes richer then there is something to purge an it continues at a low flow for 45 seconds and then takes a break if idling continues. If it sees lean it stops then and again does a break if idling continues. Above idle the throttle and engine load will determine a purge valve flow rate.
For that vacuum to be present in tank the shutoff is stuck closed or the vent hose with filter on end (up in quarter panel attached to filler neck). The normal functioning of purge valve would build vacuum with a block tank vent.. The leakage testing once it is started would set faults for seeing residual low tank pressure and then aborts the rest of the leakage test.
- Been thanked: 4064 times
User Lexia published a tome on the purge cycle and readiness which is linked into my Elizabeth maintenance thread
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
Did some investigating. The purge valve was open when I removed it. Applied 12v and heard no clicking and flow of air did not change. Blew the valve out with carb cleaner, and a bunch of black gunk came out. Valve still seemed dead on the bench. Used one ordered locally from a wrecker.jimmy57 wrote: 28 Feb 2020, 15:14 The shutoff valve is there to allow tank leak detection testing. On that 98 it would only close after you drive for a qualifying period with some driving conditions met. Once you idle it can do the test and close the shutoff valve, the only reason it ever needs to close the vent line for tank. The purge valve runs a lot. If you idle for 30 seconds or so then it will do a test to see if canister has load by opening purge valve and watching response at front oxygen sensor. If it goes richer then there is something to purge an it continues at a low flow for 45 seconds and then takes a break if idling continues. If it sees lean it stops then and again does a break if idling continues. Above idle the throttle and engine load will determine a purge valve flow rate.
Removed the shut off valve and blew through it. It is open when no power is being applied. I'm assuming that is normal?
Inspected all the vacuum lines in the engine bay. All the evap hoses were in very good shape; I think someone was here before. Only hose that was bad was the vent hose had a big slit in it. And this elbow on the manifold was torn. Thinking the vent port on the charcoal canister may be blocked now. How do you remove it from the car? Haven't been able to figure that out.
Knows enough to be dangerous
- WhatAmIDoing
So, I blew through the purge hose and air came out the vent hose. When I plugged the vent hose, I could hear an air leak from the left rear near the fuel tank. So I think the canister and the shut off valve are okay.
All I can think to do now is trace the vacuum leak by the tank. And maybe there's a ground short giving the shutoff valve power all the time?
