What do you think? Topic is solved
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
- Pete -
Year and Model: 01, 04, 04, 04 V70's
Has thanked: 80 times
Been thanked: 175 times
Re: What do you think?
Post by - Pete - »
Crunch crunch. It tends to happen in winter.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
Has thanked: 1505 times
Been thanked: 3818 times
Worst case it ****might**** need another 1500-2000 to refresh everything to new. From there, you can expect 300,000 miles from that car
CaptainWeenieWagon
Year and Model: 2004 V70
Has thanked: 2 times
Post by CaptainWeenieWagon »
What kind of upgrades can I do instead of just replacing?
Any sites I may need to familiarize myself with?
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
FCPeuro.com! Forum sponsor (at least I'm pretty sure they still are) and they have the best customer service out there. Price and selection are both great as well.
CaptainWeenieWagon wrote: 08 Mar 2020, 18:14 What kind of upgrades can I do instead of just replacing?
This is a high end car with high quality parts
Most of the “ upgrades” are inferior parts compared to OEM
Georgeandkira
Year and Model: '07 V70 + '15 XC70
Has thanked: 64 times
Been thanked: 69 times
Post by Georgeandkira »
Some will say "Volvo brakes only". Others go with lower dust options as an "upgrade".
I say Bilstein shocks and struts are an upgrade.
Many praise the thicker sway bars sold by IPD.
Many go zonkers over audio options.
There's plenty to do before you optimize your new ride.
You must visually inspect both rear parking brake hardware sets (left & right).
Also perform a glove test on the oil filler neck. This relates to the PCV system
You should do at least one transmission drain and fill (automatic, no?) to see & smell how foul the fluid is. If you've heard that our trannie fluid is "lifetime", you must have that section of your brain removed.
The coolant may be due for a refresh due to age or contamination.
Any service records? You likely need to replace the timing belt. You may be overdue for a complete "Stage 0" tune up.
The cabin air filter in any car can be overlooked.
A brake fluid flush and pin lube might be in order.
Check the spare for air and make sure the jack and wrench are there.
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
Check the battery age and battery cable condition. These cars must have top condition battery to function properly. Confirm the charging system is strong. Obtain a code reader for Volvo or the full Vida Dice setup.
CaptainWeenieWagon
So I need to replace a broken shifter in this automatic 04 V70 and I was wondering if anyone knows of any other options that fit? I can get an original for $32 on eBay. Just wanted something different. I have a spare lone shifting rod that I purchased to use a shifter I already had but no dice. Doesn't fit. Thank you for your time!
bmdubya1198
The stock one is probably your best bet.
Grab one from a junkyard, wonder how it broke?
