Overheating Not really Topic is solved
Help, Advice, Owners' Discussion and DIY Tutorials for the groundbreaking new Volvo S60 2011+, V60 2015+ XC60 2010-2018.
RickHaleParker
Been thanked: 958 times
Re: Overheating Not really
Post by RickHaleParker »
SuperRoy wrote: 03 Apr 2020, 09:01 Dealer is involved now....replaced the new battery from Advance Auto with what he's calling a Volvo battery. Says the car sensors won't work properly with any other type of battery. What's your opinion
Also said that the cooling system had an air bubble that was causing the sensor to read low fluid level....
Both are nonsense. The dealer is taking you for a ride or it is gross incompetence.
Volvo batteries are good quality but they are lead acid batteries just like any other brand.
Bubbles in the cooling system will not cause the sensor to read low unless it cause the level in the reservoir to go low.
SuperRoy
Year and Model: S60 t5 Premier 2016
Has thanked: 1 time
Post by SuperRoy »
My thoughts also
BUT, he's made her a happy customer with getting the warning message taken care of
RickHaleParker
SuperRoy wrote: 03 Apr 2020, 12:57 BUT, he's made her a happy customer with getting the warning message taken care of
Oh! he got the heat of you ... that does make him a good guy.
SuperRoy
Has thanked: 1 time
Post by SuperRoy »
It's been weeks now. Dealer has replaced the thermostat looked at what they say is everything... Car still reporting overheating. Replaced the water pump... I'm leaning towards a warped head...which is allowing anti freeze to enter cylinder on the intake stroke. But this is strange. The anti freeze reservoir is draining down to where the sensor says it needs more anti freeze, when the cap is removed to the reservoir for some strange reason it has air pressure in the reservoir then fills up with anti freeze coming from somewhere. driving my sister nuts Any one ever seen this before
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
This was a good read, thanks. Quacks can sometimes be right? is there white smoke from the tailpipe, i think the cylinder is pressurizing the coolant.
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
SuperRoy
Has thanked: 1 time
Post by SuperRoy »
After several months of taking it to the Volvo dealer. Maybe, now it's resolved. All is covered under her maintaince contract that was purchased when she got the car from a used car lot. The dealer has finally taken the head off of the engine, in doing so found that the head bolts were loose, After replacing the head gasket and torquing the head bolts correctly it seems to be corrected, but it's only been about 2 weeks, so we will have to see what happens.
