Thanks for the follow up on the Denso Plugs.
I run mine at .040"
In later years Denso shows a gap of .028" (Actually 0.8 mm which is .031")
The later twin tip plugs are used in the 3.2 and the 3.0T
For Turbo applications a smaller gap is typically used because the boost increases the needed Voltage at the coil. The smaller gap reduce the voltage requirement to form a good spark.
I am replacing plugs every 50,000 miles.
For my 3.2' I own
2008 LR2 3.2
2010 S80 3.2
If you want to see what goes wrong on 3.2's over 100K then take a look at my thread on the land rover board
https://www.freel2.com/forum/topic32504.html
And if you want to read about me doing most of the items listed in the above link for my S80 3.2
viewtopic.php?f=31&t=87687
The pictures are great and very helpful
Thanks for posting them.
Note: the motor mounts for your P2 are different than my P3 vehicles
Thanks
Paul
SPARK / ignition issues, changed plugs to NGK - worse. Was FoMoCo tri tip sparks before Topic is solved
- 1519 Views
Last post by QUARKS40
- 27 Replies
- 11728 Views
Last post by dono
- 791 Views
- 1447 Views
- 1154 Views
Last post by wizechatmgr
