All instruments gone, then back Topic is solved
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
It can be repaired in DIY.
There is a topic around here on MVS and i just came across it few days ago.
Of course....it can be something simpler like bad connection or bad earth.
Remember....simpler things first! ;)
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
I left out "not". Yes, do check the ignition switch. Most warning lights that come on in run position II are instantly illuminated when you move key to that position. turn the key very slowly to pos II and then with feather touch move it slightly CW and CCW while watching to see if the warning lights flicker or go off. Ignition switch issues can usually be detected like this.
Clemens
Has thanked: 500 times
Been thanked: 228 times
Post by Clemens »
erikv11 wrote: 31 Mar 2020, 19:41
Amazing that it is on original wires, TBH. How many miles/kms? Bet you might notice a change if you decide to swap them.
About 200.000 miles. It is in overall really good condition, just 2 POs, both took good care of it.
1996 855 R,
2010 V70 D5,
Clemens
Post by Clemens »
misha wrote: 01 Apr 2020, 05:11 It can be repaired in DIY.
I came across that link on how to fix that thing right after ordering a new one ...
1996 855 R,
2010 V70 D5,
Clemens
Post by Clemens »
Just a quick update: 2 weeks ago the ABS/Tracs light came on, so I decided to finally install the ignition switch that I had orderer back in March.
As for now, everything seems to be back to normal, even though the old switch didn´t look nearly as bad other ones I had seen on here (Steve had a pretty nasty one, if I remember correctly). The feeling of the new part is alot different, it really feels tighter and newer.
I hope this saga won´t need to be continued.
Clemens
1996 855 R,
2010 V70 D5,
Has thanked: 2207 times
Been thanked: 1852 times
We are hoping along with you on that!
