It may have been working intermittently or very poorly at the time, I don't remember completely (almost 2 years ago now) but referenced an old post that I made in my Swedespeed thread 1 week before getting the AC recharged. In that post I mentioned the compressor stopped clicking on and off at allRichard99 wrote: 10 Apr 2020, 10:48 You mentioned that you recharged the A/C with your A/C compressor not working. How did you do that? It usually won't take a charge unless the compressor is running. I had to jump my compressor to get the gas in last time I did it.
850 Air Conditioning Woes
sventastic
- Year and Model: 1996 854R
- Been thanked: 6 times
1996 854R | M56H | 16T | 274k | BC, Canada
I had this car too when I was in Dubai. Then the ac of my car not working well. So I contacted ac maintenance in Dubai as I couldn't contact with the car company. They fixed my ac problem.
JimBee
- Has thanked: 33 times
- Been thanked: 43 times
Eric the Car Guy made the off-hand comment that 80% of freon leaks are at Schrader valve in the filler port. It looks like a tire stem but it's a little bigger and you need a special tool to change it. NAPA has them for ~ $8.00 branded for GM but appears to be the same thing Volvo used on the P80's.
- Has thanked: 1611 times
- Been thanked: 4075 times
80% of statistics are flawed , including this one
Wcm and I played with a $20 sniffer from HF to track down a bad o ring (s) on His P80
I’ve done about a dozen AC jobs now, Evaps were half of them, two leaky compressors , two rusted out driers, one space alien , and the rest bad orings in lines.
- smacknab
- Has thanked: 97 times
Not sure how often the lines fail, but I rented an ac cleaner kit that hooked up to an air compressor from my parts store (US) for free and bought some cleaner fluid to flush them out. Not sure if that helps, but so far they seem to be fine on my car with 215k miles.
The positive is the evap isn't that expensive just make sure you but a set o-rings as Abscate outlines. I bought two of the AC o-rings kits from FCP euro and it covered me with extras. (I don't remember if I needed two, but it was cheap insurance). If you have a squaky dash like I did, it could be a good time to fix the dash mounts.
There is a diy PDF on this site that I used, and RobertDIY has some youtube videos to help you through it as well.
07 V50 T5 AWD M66 ~146k miles
Just did some P80 AC work recently and noticed that FCP didn't have the Scantech AC Oring kits anymore.
I also documented in this Forum that these kits don't have a complete set of o-rings, so get to the Volvo webstore and buy these from the Volvo Diagram
sventastic
Thanks for the info! Thankfully I don't have a squeaky dashsmacknab wrote: 28 Jun 2020, 18:00 Not sure how often the lines fail, but I rented an ac cleaner kit that hooked up to an air compressor from my parts store (US) for free and bought some cleaner fluid to flush them out. Not sure if that helps, but so far they seem to be fine on my car with 215k miles.
Good to know, thank you!abscate wrote: 28 Jun 2020, 18:26 Just did some P80 AC work recently and noticed that FCP didn't have the Scantech AC Oring kits anymore.
I think I'm going to relegate the A/C work to a fall/winter job and just deal with it for next summer. We're having a very cool summer so far and I'm filling my weekends with backpacking and biking so I'll suck it up for the time being
- Roger_850T
- Year and Model: 854T 1995
- Been thanked: 26 times
I like this approach - before randomly replacing parts, test and determine where the fault lies. The way it stopped working over time suggests it may be just a slow leak and is now empty. Or it may be a rusted component. Test and see!abscate wrote: 28 Jun 2020, 13:22 80% of statistics are flawed , including this one
1. Get a gauge, check for any pressure in the system. Likely zero if it's all leaked out, but check first. If it has a charge, then need to determine why it doesn't turn on.
2. If no pressure, then get a vacuum pump and draw it down, see if it holds vacuum or not.
3. Consider adding some refrigerant with the UV Dye in it.
4. Visual inspection of evaporator and compressor and accumulator may suggest issues. (i.e. visible rust and corrosion may be an indicator.)
5. Use the halogen detector as Abscate did, and see where it's actually leaking from.
6. Once the leak is determined, replace as necessary.
I hope this helps - good luck!
Roger
11 XC60 137k
08 V50 Project... Still in pieces
05 XC90 V8 213k
95 854T 350k Still my favorite daily driver
02 V70 186k+ Gave to my daughter, still going strong
03 S80 111k (crashed, but driver walked away unhurt)
93 945T 217k (gone to be parted out)
87 245 300k+ sold, still going afaik
84 264 Diesel, RIP at 160k
78 242 manual everything.
73 P1800ES, fun until the rust set in...
05 XC90 V8 213k
- Eddystone
- Year and Model: 1967 Ford GT40 Mk IV
- Has thanked: 63 times
- Been thanked: 81 times
"Remember they have a 100% failure rate. And if it's older than say 8 -10 years it's shot. The original would have been gone years ago..."
I could be wrong, but I would beware of categorical blanket statements like this, especially given the cost and labor involved in swapping in a new one. Where I live,P80s with 150k in quite decent shape are going for $1500-1800, and I find that any non-enthusiast using these as daily drivers are not putting that kind of money into these cars. In fact, when they need something as simple as lower control arms, people don't want to foot the bill to have a mechanic do the work on a high mileage car that's over20 years old. That means that many of them have the original condensor or have been junked. Neither of my P80s have issues with leaking condensors, and one came with extensive service records, so I am with Misha on this one.
That's not to say that the car in this thread doesn't have a bad condensor or that even a good one will fail sometime before the sun expands and absorbs the inner planets.
All U.S. market models.
All running and on the road.
Wait, what?That's not to say that the car in this thread doesn't have a bad condensor or that even a good one will fail sometime before the sun expands and absorbs the inner planets.
Well, screw getting that new battery then. It’s still got a good 15 minutes of reserve if I leave the parking lights on.
