98 XC Power steering fluid preferences
misha
Year and Model: '97 850 2.5 20v
Has thanked: 152 times
Been thanked: 402 times
Re: 98 XC Power steering fluid preferences
Post by misha »
MoVolvos wrote: 26 May 2020, 16:49 ...I believe the 98 calls for DEX III (transmission fluid) in the powersteering so the Havoline covers the DEX III and 3309 for the transmission also.
ATF spec doesn't matter for power steering.
The most important thing is that it's red ATF.
Just regular red ATF is fine.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
misha wrote: 26 May 2020, 16:55
I think Mercon and others are red also? Always select what is spec'd then brand rather than color.
misha
Post by misha »
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
MoVolvos
Post by MoVolvos »
misha wrote: 26 May 2020, 17:10 Power steering fluid quality:ATF.
http://new.volvocars.com/ownersdocs/199 ... .htm#pg134
Thanks for the information. Sorry, I was thinking of Type F which is also red and by Ford. I knew there was a Ford red transmission that was not compatible with others and couldn't think of it as Mercon is the more common and I've never own anything which used Type F.
https://itstillruns.com/substitutes-dex ... 02226.html
Ford/Volvo used both the Mercon and DEXIII though they are different chemically and one has a higher flash point. Volvo spec'd both for the transmission and powersteering which indicates they are close enough. There are many more transmission fluids that are "red" so just don't use any red transmission fluid but DEXIII or Mercon compatible.
Now a days many Synthetic will be backwards compatible so look at the specs on the bottle.
Has thanked: 292 times
Been thanked: 765 times
Post by erikv11 »
Dex III (red) ATF.
I use Mobil 1 synthetic ATF in the P80 PS reservoirs, even though I use cheap SuperTec Dex III for the P80 transmissions.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
Has thanked: 1846 times
Been thanked: 1710 times
Volvo parts guy was a little confused. As has been said above, DOT 3, 4 is a term normally used for brake fluids. Many of the younger parts guys and even some of the older guys have no idea about 20+ year old Volvos. When I helped out in the parts department for a short time as a favour a few years ago, most of the guys were pretty good, and some including a couple of young guys were excellent. They also ran older Volvos and were keen to learn more. We are lucky they are still there and doing well. 2 of the parts guys are former mechanics so have a greater understanding of what goes where. Sometimes it is just luck who you get.
Anyway, I think the question has been answered.
Good Luck!
Has thanked: 1502 times
Been thanked: 3817 times
On older cars with lots of drivers in my fleet I use the same product in my AT and my power steering so I only have to carry one liter off top off fluid
I used the Valvoline Dexron VI synthetic in the E83 trans and PS, and the S70 trans and PS when those cars were in college.
ZionXIX
Has thanked: 64 times
Been thanked: 194 times
Post by ZionXIX »
With OEM power steering racks becoming difficult if not impossible to find these days, has any tried rebuilding their own steering rack on the P80 cars?
The hardest part is finding repair kits. I looked hard a few years ago and believe I got some from Corteco. It does not have the top dust shield for where the steering column attached to the rack. They did not have anything that size.
JimBee
Has thanked: 25 times
Been thanked: 42 times
Post by JimBee »
This blog thread by Bobistheoilguy has a couple of interesting posts, including one that compares the viscosity spec's of Amsoil's ATF vs their PSF. One poster discusses all the different hydraulic systems his machines have and he uses the ATF. The consensus is use the ATF. The PSF is slightly less viscous than the ATF. I wonder if there's likely to be any different effect on the rack seals—isn't that the failure point for a rack?
https://www.bobistheoilguy.com/forums/u ... er=2444830
