ETM (Main Relay) making loud audible clicking sound
- 800artfreed
- Year and Model: 98 S70T5; 99 S70GLt
- Been thanked: 26 times
Please check your ground wire connections. There are many throughout the wiring harness. Check out Youtube.com and learn about conducting voltage drop tests. Please test the voltage drops for the main battery + cable and the - cable from the battery to the chassis ground. Try to understand where VIDA was indicating where it found the 10.49 volts. That the first place indicative of a problem. After you get it running make sure the alternator voltage is around 14 volts to fully charge the battery.
VolvoVoyeur
1998 S70-T5 200K+
1998 V70-T5 200k+
1999 S70-GLT 80k+
1998 S70-T5 200K+
1998 V70-T5 200k+
1999 S70-GLT 80k+
- 799 Views
Last post by subzerocarfanatic
- 1066 Views
Last post by Clockboy
- 57 Replies
- 27973 Views
Last post by shadetree_v70
- 881 Views
Last post by xHeart
- 14 Replies
- 6477 Views
