You missed the point of my post. I know you have an N engine.
You can use an RN engine in place of your N engine without having to add any of that stuff.
You can swap the engine. Gain the better RN oil cooler set-up. Keep all of your current engine controls and ignition. Hell, you can keep the crappy oil cooler set-up if you want.
I mentioned the additional stuff because it was a possibility for scaling later.
98 V70 xc engine weight and recommendations
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
- CIK7
- Year and Model: 2026 Sportrailer GLT
- Has thanked: 350 times
- Been thanked: 108 times
oh ok. what's better about the RN oil cooler?Chuck W wrote: 11 Jul 2020, 21:39 You missed the point of my post. I know you have an N engine.
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
- Chuck W
It's located on the oil pan on the back of the engine. No silly lines to/from the engine to the radiator.
You can see it here on my current engine going back into my '97 T5. (Doing a manual swap, and also doing an RN oil pan upgrade)
- CIK7
ah yes I remember that. that was on my 01 V70 baseChuck W wrote: 12 Jul 2020, 18:46 It's located on the oil pan on the back of the engine. No silly lines to/from the engine to the radiator.
- Has thanked: 311 times
- Been thanked: 817 times
Everything!
But seriously, the N oil cooler setup and hoses is a complete PITA and I would seriously consider going to the biscuit cooler if you are doing engine work. You can also just swap in the RN oil pan and coolant pipes, just to get the cooler on an N setup.
- Chuck W
That is what's happening on my N motor. With that and the manual swap, I'll have NO oil/trans lines out to the radiator from the engine.erikv11 wrote: 13 Jul 2020, 07:58
- CIK7
thank youerikv11 wrote: 13 Jul 2020, 07:58Everything!
- 1905 Views
Last post by darylrobert
- 727 Views
Last post by PixelDust
- 2311 Views
Last post by mtroxel
- 2039 Views
Last post by tryingbe
- 4956 Views
Last post by coded9
