need some info about a popular p80 engine upgrade Topic is solved
callahanoffroad
Year and Model: 1995 850
Has thanked: 16 times
Been thanked: 53 times
Post by callahanoffroad »
There's no reason to drive without a hood. Unless yours got ruined in a crash. 300 hp is not that much power to do something so drastic. S60r's make over 300hp on what is essentially the same engine.
You should check out volvospeed they're more power and performance oriented on that forum.
Basically the stock T4 turbo that the Volvo's run is the big limiter. Turbos are sized for a certain amount of performance. If you want to make power outside of the stock range you'll need a larger turbo.
What are your actual goals? I think that will get you some better responses. :-)
Author, Chef, and Shade Tree Mechanic
1995 Volvo 850, Non-Turbo, VVIS, LH FI, Green, 215,000 miles. B5254FS engine. Herman. viewtopic.php?f=1&t=84393
1996 Volvo 850, died at 280,000
Founder of: CookingForChemo.Org
Read my Silly Comic Book at: therealpizzabros.com/
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
FLXC90 wrote: 28 Jul 2020, 19:22
Chuck W wrote: 28 Jul 2020, 10:07
FLXC90 wrote: 27 Jul 2020, 21:42 For most purposes Blue/green injectors will work interchangeably,
Blues and whites are the "interchangeable" ones. Greens are bigger than both (By about 20% flow rate).
yep, my bad.
310cc (orange) - 1995 T5R, 96-97 850R
350cc (white) - 98 T5 models
395cc (blue) - 99+ T5 models
465cc (green) - S60 R, 99-00 V70R
Thanks Chuck, I don't want to leave bad info here.
I just remember the info from the M4.4 Wiki page. If I recall the difference in the white/blue flow rates has to do with the operating fuel pressure. When they are used at the same pressure, the flow is the same/similar.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Yea, whites and blues flow exactly the same in the same car, e.g. 350 cc in a 98 C/V/S70 car. Blues came installed on cars with higher pressure FPR (99 and 00 T5), where they accordingly flow higher (395 cc). OK, what Chuck said.
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
Regarding driving without a hood - From what I have encountered in California and Arizona ( probably most western states ) you do not need to have a hood installed to use the car. You do however have to have functioning hood latches, if you do have a hood, to prevent it being blown open while your driving. There is no real safety issue driving without one, so they don't care. By comparison fenders are a whole other matter since driving without one is a safety issue due to rocks etc being thrown into other cars, so a fender has to cover at least 45* from the top of the tire down. Becomes an issue with the old open wheel roadsters and hot rods, many of which also do not have hoods.
1999 V70 GLT
CIK7
Year and Model: 2026 Sportrailer GLT
Has thanked: 350 times
Been thanked: 108 times
Post by CIK7 »
callahanoffroad wrote: 29 Jul 2020, 04:57 There's no reason to drive without a hood. Unless yours got ruined in a crash. 300 hp is not that much power to do something so drastic. S60r's make over 300hp on what is essentially the same engine.
The reason abscate mentioned wisconsin is because im planning to go on a road trip in 2-3/2021 from oklahoma where i live to wisconsin. Coldest air might make my car even more fun; which would be the point of going hoodless.I have already posted on a few of my own threads that i will be running the 19t. What is the T4 turbo? i havent heard of that. unless your are referring to the b253t4 engine. the 2004 s60r auto runs at 300hp/258tq and manual runs at 300hp/295tq. I think on my planned setup, I could make almost 300hp.
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
96 964 silver, 146K, diff&trans/engine self-destr, crushed 😭
FLXC90
Year and Model: 98 V70 T5
Been thanked: 45 times
Post by FLXC90 »
T4 is the physical size class of the TD04 turbos. T3 was a Garrett AiResearch series, then they came out with T4s, and have kinda been a standard by which many turbos were measured cfm wise. It's a before your time thing.
Current Volvos:
CIK7
Post by CIK7 »
FLXC90 wrote: 29 Jul 2020, 16:31 T4 is the physical size class of the TD04 turbos. T3 was a Garrett AiResearch series, then they came out with T4s, and have kinda been a standard by which many turbos were measured cfm wise. It's a before your time thing.
i see...
Chuck W
Post by Chuck W »
CIK7 wrote: 29 Jul 2020, 15:23 The reason abscate mentioned wisconsin is because im planning to go on a road trip in 2-3/2021 from oklahoma where i live to wisconsin. Coldest air might make my car even more fun; which would be the point of going hoodless.
This makes no sense. :? Leave the hood on.
