Timing Belt &water Pump Time...
850oldschool
Year and Model: 1996 850 NA
Been thanked: 45 times
Re: Timing Belt &water Pump Time...
Post by 850oldschool »
erikv11 wrote: 20 Aug 2020, 22:32 Coming from an S40, you sure that water pump fits your 98 NA? I'd probably use it if it does, or buy a Hepu if it doesn't.
This is the first good word I’ve seen about a Hepu on a Volvo. I put one on a VW and it went over 100,000 miles with no issues. I know you rack up the miles so I trust your opinion.
Eddystone
Year and Model: 1967 Ford GT40 Mk IV
Has thanked: 63 times
Been thanked: 81 times
Post by Eddystone »
erikv11 wrote: 22 Aug 2020, 08:21 So you figured out your car needs a hydraulic tensioner not the mechanical one?
I'd get this, $200 https://www.fcpeuro.com/products/volvo- ... kit252-oem.
Ordered that kit from FCP
Ordered the Aisin water pump without the bolts from Amazon for $57. Also, the CTA-2883 cam locking tool from Amazon. I had a credit there and will need a pump for the other car soon, as well. That will put off the decision about whether or not to use the Gates pump I have. Actually, I don't put much mileage on these cars. If the Gates pump failed after 25k miles, it may fail on my heirs.
For the later 1999 S70 with mechanical tensioner, there is actually an Aisin kit on Amazon that has all the parts including pump for only $134. The text says it includes a "Mitsubishi-sourced" timing belt, but the one in the photo is a Gates.
All U.S. market models.
All running and on the road.
wheelsup
Has thanked: 15 times
Been thanked: 20 times
Post by wheelsup »
That seems like a legit deal
wheelsup
Post by wheelsup »
Eddystone wrote: 22 Aug 2020, 10:31
I did mine without a cam lock. I didn't find I needed it FWIW. If you move them by accident you can just rotate them ever so slightly. Get some whiteout and mark the corners as they point to the plastic cover.
You can see the marks here:
viewtopic.php?t=83972
Good advice in that thread of rotating it around a few times once the new belt is on. I did that and still, going to turn the key, that's a heart stopper.
I used the AISIN waterpump as well IIRC.
Has thanked: 1502 times
Been thanked: 3817 times
To clarify
You don’t need the cam lock tool for anY -1998 car with no VVT
YoUdont need the cam lock tool for a 1999 NA which also don’t hAve VVT
From 1999 turbos on, you don’t need the cam lock tool to do a timing belt if the VVT HUBS stay in place
From 1999 on, if you are doing cam seal on VVT CAMS, or other work requiring Removing the VVT, you do need the cam lock tool.
