Is there a partial short circuit along the way. That seems like the light is not getting its full voltage, are any wires damaged or cut?Check the relays and ensure that everything is in its plug correctly.
When you blinked right it looked like left was triggering partially, are all the connectors for the left and right separated properly.
Are there LED's in the lights. The flast blink is strange, i believe the light control module is in the hazard signal button. It should all come out as one piece.
I can upload a video of what the blinking should look like. You should not get any blink on the other side. That tells me that the left and right might be partially connected somewhere, or the relay may be defective.
C70 wiring diagrams? Got some plugs hanging "in the air" in the
yanga001
- Has thanked: 62 times
- Been thanked: 115 times
2008 S60 2.5T Auto (Sold)
eightfifty2x0
- Year and Model: 1996 850
- Has thanked: 10 times
- Been thanked: 3 times
I haven't observed any wrong connections or even damaged ones but somebody told me that the parking assistant might be falsely connected. Because this car was reared and now fixed, but by somebody who just fixed the body, not necessarily the electronicsyanga001 wrote: 14 Sep 2020, 20:02 Is there a partial short circuit along the way. That seems like the light is not getting its full voltage, are any wires damaged or cut?Check the relays and ensure that everything is in its plug correctly.
eightfifty2x0
And the thing is, that before I took the car to the body workshop, it was all fully functioning. So it is definitely something wrong with the connections. Might be the parking assistance, that is wrongly connected
- Has thanked: 1611 times
- Been thanked: 4072 times
Those ground wires need to be, grounded.
Get the wiring diagrams and the listing of. Every ground points in the rear and get checking. Whoever left off those left off others, too. No competent electrical work leaves grounds loose
eightfifty2x0
The ground cables on the pictures are the only ones i observed. I dont know whether within the rear bumper are more of those. Because the rear bumper was removed in order to repair the bodyabscate wrote: 15 Sep 2020, 03:27 Those ground wires need to be, grounded.
eightfifty2x0
Hi, adminos! I fixed the issues. I guess there was some software issue because when i took it to some Volvo pros(not Volvo dealer) they "read" the errors and deleted them. Since then it all works fine.
- Stu70
- Year and Model: 2006 Sonic VR GT
- Has thanked: 34 times
- Been thanked: 26 times
Glad you got it all sorted
Are the ring terminals still hanging in the air, Or are they tucked up under the carpet screwed into the bodywork? I no doubt imagine the specialists charged you to ‘delete the errors in the software’ ?
1998 S70 10v BiFuel - Sold
2006 Sonic V70R - “this is going to be expensive “
eightfifty2x0
25 euros. YesStu70 wrote: 21 Sep 2020, 01:29 Glad you got it all sorted
- 1256 Views
Last post by MadeInJapan
- 59 Replies
- 33431 Views
Last post by Twarr12000
- 1161 Views
Last post by Philgault
- 1058 Views
Last post by Eddystone
- 3190 Views
Last post by RickHaleParker
