Programming new key/remote
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
FordTaurus00
Year and Model: 2004
Has thanked: 1 time
Re: Programming new key/remote
Post by FordTaurus00 »
JKXC wrote: 21 Sep 2020, 06:49 Hi, I just went through this and did it myself. I had the keys programmed by a place in Kansas City that specializes in car keys (https://www.brandtlocksmiths.com). They cut the key for $10 using my valet key to copy it -- though it will be more if they have to look up the key code based on your vin (shipping was about $16 roundtrip). I would call the ahead of time to verify they'll do this for you. I live in a rural area where the only 2 locksmiths here wanted $100 to copy the key, so I found another alternative online.
Good to know as well. I still haven't found someone that can copy my valet key to the flip keys. If I understood you correctly, you mailed your keys to that locksnith. They cut them. And mailed them back?
JKXC
Year and Model: 2005 XC70
Has thanked: 3 times
Been thanked: 5 times
Post by JKXC »
Brandt Locksmith had no issue cutting the new key with my valet key. I had an extra normal key but they said just send them the valet and they can use that. So you should be good to go that route. They specialize in car keys so they know what they are doing. I also only sent them the blade end of the key to cut it.
JKXC
Post by JKXC »
Sorry, just re-read your question. Yes, I mailed them the valet and the new key blade and they cut them and sent them back. Just give them a call before you do so. I found them via one of their employees on Reddit Locksmith sub who helped me out. It was very fast and the key works perfectly. They are kinda an old-school shop that isn't specializing in doing online/mail orders but I think they'll do it so long as you speak to them first.
Yaworski
Year and Model: 2002 S60
Has thanked: 5 times
Been thanked: 3 times
Post by Yaworski »
I found a local locksmith who'd cut the keys, knowing that he couldn't program them. There's a simple workaround for programming.
I went to a junkyard and got a new ring antenna, cost me a few bucks. I then took the steering column covers off, disconnected the existing ring antenna, plugged the junkyard antenna in. I then ziptied the working key to the junkyard ring antenna, experiment with orientation to make sure that it works. Everything was secured in place and the steering column was reassembled.
So the keys cost me about $30 for four, I only needed three but they came in pairs. Cutting all four cost $100.
ETA: That was $130 for four keys and a bit of my time. I needed a spare key for my 2001 V70 and didn't know about the "workaround" so I foolishly went to the dealer and one key with programming cost me $150.
arrrxivvv
Year and Model: 2004 XC70
Has thanked: 16 times
Been thanked: 10 times
Post by arrrxivvv »
I recently tried the same thing, to program to key myself. After purchasing VIDA it rejects my DICE clone, so Volvo probably have flagged those Chinese units.
Fortunately I was to use VDash to program the keys, $25 one time purchase and I was able to program two ignition keys and remote.
04 XC70 206k
kcodyjr
Year and Model: 2006 S60 2.5T AWD
Has thanked: 17 times
Been thanked: 23 times
Post by kcodyjr »
arrrxivvv wrote: 30 Apr 2021, 15:09 Fortunately I was to use VDash to program the keys, $25 one time purchase and I was able to program two ignition keys and remote.
I've got to wonder if there's a "catch" to this... are the keys really programmed the same way that VIDA would, and each is uniquely recognizable, or does the car now think all the keys are the same one?
5 others that came and went
kcodyjr
Post by kcodyjr »
JKXC wrote: 21 Sep 2020, 06:49 $87 for the key programming and remote programming (each is an independent purchase through volvotechinfo.com -- one for the key to car and one for the remote).
So the key and the remote are two logical units, even though it's only one item that you hold in your hand? Real cute, Volvo.
Is that $87+$87=$174 for each new key, or for as many keys as you want?
arrrxivvv
Post by arrrxivvv »
kcodyjr wrote: 30 Apr 2021, 17:30
Good question, I'm not complete sure. But I did use VIDA to check this, it now sees three keys stored, and can tell each keys separately when I plug them in (key number 1, key number 2, etc).
04 XC70 206k
XC702006
Year and Model: 2006 XC70
Post by XC702006 »
I'm in a real Jam, just got the car. Worked on replacing the rear emergency brakes had to change the knuckles, dust sheeld and all the other internals. Finaly certified on Friday. I drove it for about an hour. Went in decided to change the key fob to a new one and get the key flipping again Wasn't thinking and broke the transponder chip :( I have no keys and the dealer is over 4 hours away. Can anyone help out, for the money its going to cost to tow it and have new keys made, its probably worth learning how to do this myself. Can someone please PM me with how it could make this happen.
Thanks,
JKXC
Post by JKXC »
If you're able to get mail the easiest thing to do would be to buy a replacement key, get it cut (though mail via the link in this thread) and then program it to the car, either using VIDA/Dice or Vdash, etc. In theory you could do all of this without having to drive anywhere, if you get mail.
Are you sure the chip is broken? I would try to just tape it near to the antenna or on the key and see if it will start. It might just work...
