850 intermittent yellow arrow light
- Clemens
- Has thanked: 500 times
- Been thanked: 228 times
I had a flashing arrow on my wifes 850 a while ago when the temperatures were quite cold right after startup and when putting it into reverse at the end of the street. It never happened otherwise. I have no clue what the problem was, but these things can be random or intermittent.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- Has thanked: 1611 times
- Been thanked: 4071 times
You are probably getting transmission error codes you can read with VIDA software
- Has thanked: 2207 times
+1 with abscate on this one. Otherwise you could end up throwing money trying to fix the issue. Only other 'cheap' thing to try is to drain and refill the trans oil (about 3.5 liters). If it is really cold, have you checked the oil level when cold in the trans, and when was it's last trans oil change?
Cailin
- Year and Model: 1996 850
UPDATE: although I posted this years ago, I’m just now back on this site. On the off chance this will help someone- this issue was the ignition going bad. The ignition wasn’t communicating properly with the transmission, so it would default to “limp home mode”.
Awesome follow up. Was that ignition switch bad or something else?
- 13 Replies
- 4257 Views
Last post by Clemens
- 1243 Views
Last post by 95850turbowagon
- 2280 Views
Last post by Scholz
- 1181 Views
Last post by precopster
- 541 Views
Last post by jonesg
