stripped a screw - badly
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
SuperHerman
Been thanked: 207 times
Re: stripped a screw - badly
Post by SuperHerman »
Agree with abscate. Is the bolt aluminum? They like to snap - so be careful. Torque from a wrench or vice grip may apply forces in the wrong direction.
If abscate's recommendation doesn't work, I would cut a slot and repeat and turn with a screw driver. Torque will be applied to threads.
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
Bolt is anodized steel.
I would not heat it with the torch: the valve cover in this engine has integrated journal bearings for the camshafts. Spray it with PB Blaster and try to break it loose over few days.
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
Option #1: Smack the top of the bolt with a hammer then try turning it.
Option #2: Spot Weild a nut on it. Place the nut on top then spot weild in the center of the nut. Then use a ratchet to turn it out.
Option #3: JB Weild a nut on it. Then use a ratchet after 24 hours.
Option #4: Soak the hell out it with penetrating oil oil. Then drill with a left hand bit. The counterclockwise direction of the left hand bit will spin it out. Your right hand bit tighten it up.
Has thanked: 1500 times
Been thanked: 3812 times
I stripped one out of Grunhilde and used a chisel to punch the head ccw to start it, applied PB Blaster, then vice gripped it off.
SuperHerman
You can always drill a hole through it if PB Blaster soak doesn't work. If you have left hand thread drill bits it may actually pull out while you drill. Go about 1/4 to 1/3 the size of thread and keep it straight. The heat and vibration from drilling has worked every time for me. With the bolt head on it is the easiest time to drill - once it is snapped off getting it centered and keeping it straight becomes more difficult.
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 479 times
Post by jonesg »
cut a slot with dremel disk , use impact screwdriver to knock it loose.
28 seconds of heat
If you really are nervous you can use a IR temperature probe to monitor the head for excessive heat beyond the running temp
I've already done that for you, though. Keep it under 200F and it will be fine
moncureww
Year and Model: 2006 S60 2.5T AWD
Has thanked: 3 times
Post by moncureww »
I tried it with some smaller channel locks - no luck. I didn't want to go nuts with it and make things worse. I'm thinking I'm just going to bore out the cover so it slides over this screw and fix it to the engine with the other non-stripped screw, then wait until I get my motor mounts done in the next couple weeks to have my mechanic pull it out. He's probably much better with stuff like this than me!
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 115 times
Post by xHeart »
RickHaleParker wrote: 29 Oct 2020, 23:00 Option #4: Soak the hell out it with penetrating oil oil. Then drill with a left hand bit. The counterclockwise direction of the left hand bit will spin it out. Your right hand bit tighten it up.
^The bit size should be a step smaller than the screw shank. OR slot across the head for a wider and deep flathead that grips end-to-end. PB and temp are your friends. I've acquired a great respect for flathead from carpentry experience.
jonesg
Post by jonesg »
air impact screwdriver will get it easy.
