cleaning water pump mating surface
850oldschool
- Year and Model: 1996 850 NA
- Been thanked: 45 times
I find that a piece of 1/8" acrylic (plexiglas) ground to a knife edge works quite well and absolutely will not gouge the mating surface.
januwan
- Year and Model: 97 850 NA 209 K
- Has thanked: 7 times
- Been thanked: 3 times
Thanks all for the good tips. I am surprised quite a few people use razor blades. There is so little room in there, it is very easy to make a mistake.
I forgot to install this plastic clip on the tensioner. Can it be installed after the safety pin is pulled out?
januwan
- Has thanked: 311 times
- Been thanked: 817 times
Access is easier if you take off the serp belt tensioner, which is just two easy bolts.
Yes, the clip on the hydraulic tensioner shaft may be installed at the end.
- Has thanked: 987 times
- Been thanked: 1075 times
Have you removed the wheel and pulled the fender inner liner toward the front? This gives good access.
volovlugnut
volovlugnut
januwan
Access is not a problem. I'm wondering if compressing tensioner a second time is a good idea.
This is the same tensioner I installed 30K miles ago (almost 6 years ago). I can remove two bolts, pull it out, compress again, and install with the plastic clip, this time. Will I be stressing it too much?
Can I push in the plastic clip on the tensioner shaft that is already installed and the pin is out?
januwan
You can compress the hydraulic tensioner a dozen times with no issue if you do it right - verrrrrrry slowly. Put it in a vice or a big C clamp, compress it a half turn every minute (or longer). Burt there is no need to remove the tensioner just for the clip. The clip is meant to go on at the end, after installation.erikv11 wrote: 24 Nov 2020, 08:12 ...
- 12 Replies
- 7445 Views
- 3343 Views
Last post by Sveedy
- 4762 Views
Last post by vtl
- 7226 Views
Last post by Volvoblackdog
- 1310 Views
