95'850 Electric headlight adjustment Topic is solved
volvoras
Year and Model: 1995 854 GLT
Has thanked: 9 times
Been thanked: 2 times
Post by volvoras »
A bit late to the party. Did you end up getting them to work?
Do you have some part#’s for those headlight motors? I found 2 types of leveler switches one with #s 0,1,3,5 and one with just a zero on the face. I cant seem to find anything on the web for the motors. I know it was not part of the US market, but I want to try and get the parts together to do it. My dreams are very unrealistic😂😂.
Yes they still work, as for the part numbers,
US Drivers side 3512451
Passenger side 9133012
they are a bit tricky to install. You need to extend them as far out as they will go, and then you need to angle the light (Do this outside the car its 100x times easier) and clip it into the back of the reflector plastics thingy
martinmoran89
Year and Model: 1995 850 T-5R
Post by martinmoran89 »
hi, where would i find those red connectors? :)
volvoras
Post by volvoras »
Is your car Lhd or Rhd? The connectors should be inside of the cabin under the kick panel on the left side of the car. There are 4 or 5 of them, all are different colours. The last one is red and there you will find the wire.
