95'850 Electric headlight adjustment Topic is solved
volvoras
Year and Model: 1995 854 GLT
Has thanked: 9 times
Been thanked: 2 times
Post by volvoras »
Hello,
I was wondering if anyone has tried to retrofit the electric headlight adjustment motors and switch into an 850 or has them already installed from the factory?
I got the motors and the switch from a junkyard, but forgot to check where the wires for the switch go, and the car has been crushed so i cant go back to look at it and figure it out. So I am asking if anyone can take some pictures of the wires from the switch to wherever they go if they have it installed or have done so.
I have checked the electrical system pdf book and I cant find where they would go. I have the plugs for the motors in the engine bay tho.
Thanks :D
Jaydiesel
Year and Model: 95 850 T-5R, 00V70R
Has thanked: 5 times
Been thanked: 12 times
Post by Jaydiesel »
I dont think your going to get anyone that knows how to do that in the USA. We never got that option in here. Which sucks..
volvoras
Post by volvoras »
well yea i know, but still its worth to try if someone has any knowledge or a non us user has some info.
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
I would love to have that feature!
Not sure why... Just seems like a great
lighting mod for the sticks and back roads.
You should be able to run your own wiring.
Here are the diagrams and component locations:
95 850 - Beam Width Adjusters.pdf
(801.3 KiB) Downloaded 304 times
I'd probably mock it all up on a bench first,
then get to work on the onboard installation.
Best of Luck! :mrgreen:
volvoras
Post by volvoras »
BEJinFbk wrote: 02 Jan 2021, 19:14 I would love to have that feature!
Yes i have looked in this diagram but i am not sure, do i need to insert wires in the 24/13 on page 2?
If so where does then the P wire for the switch come from?
The only car wiring I have done is speakers amps and subs, so this is new to me I would say.
thanks
manovlov
Has thanked: 672 times
Been thanked: 163 times
Post by manovlov »
Does this one help ?
Manov
Volvo 850 Electricals diagrams .pdf
(2.57 MiB) Downloaded 188 times
volvoras
Post by volvoras »
So I think I have found the solution if anyone will ever go trough this
You will need to check if you car is prewired for the adjustors, in the engine bay where the plug for the lights is you will have 3 plugs
1 headlight wipers
2 headlights
3 headlight adjustment.
So you will need to connect the car wires to the dash wires shown in pictures.
the 3 wires bottom right pic 1 will need to be connected to the switch trough the dash wires in pic2
you could just take them out and directly wire to the switch if you want to do it easier
this is the car wiring
red circle around the pink dimmer wire
This is for the light dimmer like all other switches on the dash and cluster, you pull this one out from the dash wiring and insert it in the switch
then you wire in the other 3 wires as shown in the next pic
wires in car= the wires you will need to run from pic 2 in the 3 empty holes to the switch if you want to do it correctly
I hope I have written this good enough, its my first guide
I will post an update with pics of it working, i am currently doing the evaporator so I had great access to all the wires
BigBlueWhale
Year and Model: 1996 855
Post by BigBlueWhale »
volvoras wrote: 07 Jan 2021, 17:03 So I think I have found the solution if anyone will ever go trough this
1 headlight wipers
2 headlights
A bit late to the party. Did you end up getting them to work?
Do you have some part#’s for those headlight motors? I found 2 types of leveler switches one with #s 0,1,3,5 and one with just a zero on the face. I cant seem to find anything on the web for the motors. I know it was not part of the US market, but I want to try and get the parts together to do it. My dreams are very unrealistic😂😂.
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
ELECTRIC headlights?! We still use oil lamps out here!
More seriously... I saw a newish Range Rover start up, and the headlights did a little robot calibration dance - up down left right until they settle in, based on the load in the car. Entertaining!
Has thanked: 1609 times
Been thanked: 4065 times
BlackBart wrote: 06 Sep 2023, 20:02 ELECTRIC headlights?! We still use oil lamps out here!
After which your weight trend is sold to your HMO who drops you from coverage
