Transmission going out.
Has thanked: 1853 times
Been thanked: 1714 times
Re: Transmission going out.
There is also a flush method on MVS which allows you to run trans oil out via one of the cooler hoses and filling via the dip-stick tube. I would also do what the guys recommend. Again, not aware of there being a filter but then I don't know everything! :D :lol:
If you decide to do the flush method, make sure you get new 'O' rings for the cooling pipe you remove. Also look carefully at the clam shell clamp when you remove it as it can only be fitted one way around. Fitting wrong way around leads to leaks and even the pipe possibly blowing off.
A drain and fill a couple of times and then a flush should make a big difference.
Good Luck!
cuhfs
Year and Model: 850,XC70,XC90,S60,80
Has thanked: 17 times
Been thanked: 28 times
Post by cuhfs »
If it has the Aisin AW55-50SN it wont have a filter "that you can get at to replace" as it is buried in the bowels of the transmission case and is not meant for routine replacment. I would recommend a few drain and fills using one of the methods you find described on this forum. They work miracles. Best shot for a cheap fix.
P.S. $40 for the filter and $X,XXX to pull the transmission, break it apart, replace the filter and rebuild transmission and reinstall into the car.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
Has thanked: 1506 times
Been thanked: 3822 times
The o-ring part number and size are located in the master o-ring thread for your reference
foggydogg
Has thanked: 83 times
Been thanked: 402 times
Post by foggydogg »
DutchSasquatch wrote: 12 Jan 2021, 15:49 According to rock auto there is a filter in it. The fluid wasn't chunky or anything, just very black.
+1 on the others on continuing the driveway fluid exchange. Somebody on the Forum can help clarify the fitler issue from VADIS, but it's way less work - not to mention way less mess - to do the fluid pump and dump.
My fist 850 started to misbehave, and I did a fluid exchange using a friends' Snap-On system. At some point I put a Park-Neutral switch on it too, but I no longer remember the sequence. Because beer.
Check back with a progress report ?
